CoCo Zigbee switch ZYCT-202
- felix63
- Domoticz version: 2020.1
Anyone seen or used the CoCo ZYCT-202 switch in combination with domoticz? https://www.klikaanklikuit.nl/nl/zyct-2 ... iging.html
Goldwing1973
- Domoticz version: Stable
Re: CoCo Zigbee switch ZYCT-202
Looks very much like a Philips Hue Dimmer Switch, only with a couple of extra buttons.
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
Amsterdam020
- Domoticz version: 3.5629
Seems that the coco can be used for sevaral lamps, the Philips can only control one light (or one group of lights) if i am not mistaken.
So coco has more capabilities for the same price.
Rp3, youlesss, rfxcom, philips hue, dsb1820
- jjnh
- Domoticz version: 2023.1
I've got a ZYCT-202 working in Domoticz with an adaption to the Zigbee2MQTT Domoticz plugin. The added adapter file is in the Github repository.
See: https://github.com/stas-demydiuk/domoti ... issues/222
Cheers,
John
Cheers,
John
Odroid N2+ 4GB, Finally updated to 2025.2, with an RfxTrx433E, Zigbee2MQTT with Slaesh's CC2652RB, Zwave-JS-UI, SolarEdge, iRobot and P1 connected.
AntoonvdOetelaar
- Domoticz version: 2020.2
Hi jjnh,
Is it still working?
I see the correct mqtt messages in the domoticz logging, but after that a lot of errors follow, I think it has to do with the plug in.
I updated the rpi, domoticz and the plugin.
https://github.com/stas-demydiuk/domoti ... issues/458
sudo git fetch
sudo git checkout v3.0
But can't get it to work.
Did put back older image of my setup, because domoticz showed more problems...
sudo git fetch
RPI3B, Z-WAVE AEOTEC GEN5, Zigbee2Mqtt, Xiaomi gateway, GPIO, I2C, 1-wire, DS18B20, P1 meter, Growatt, Buienradar, Harmony hub, Domoticz 2020.2
