I have the Bubendorff blinds connected to a Legrand Celiane switch. I have added the fibaro fgr-222 and included it in Domoticz. When I press open or close from Domoticz the blinds are moving up or down to 10 centimeters. It never go to the end, same issue when I press the switch. I am using Synology.
Any help will be much appreciated.
G
fibaro fgr-222 bubendorff
Amsterdam020
- Domoticz version: 3.5629
Re: fibaro fgr-222 bubendorff
I don't have any experience with the 222, only with another Fibaro product.
My experience is that it often finding the right setting for the parameters.
Have you checked the manual paragraph "Calibration through the Z-Wave network"?
http://manuals.fibaro.com/roller-shutter-2/
Make sure the module is supplied
Add the device to the Z-Wave network
Set the parameter 29 value to 1
The device will perform the calibration process, completing full cycle – up, down and up again
The parameter 29 value will be set to 0 automatically
Test whether the positioning works correctly"
Rp3, youlesss, rfxcom, philips hue, dsb1820
