Error: EventSystem: in *event: [string " ..."]:18: attempt to compare number with nil
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I try to make my first LUA script to warn me if the temperature is bellow/ower a number
the script works perfect in my LUA editor ZeroBrane Studio (with temp as a variable), but when I try it in Domoticz I got this message:
Error: EventSystem: in Kjøleskap alarm: [string " ..."]:18: attempt to compare number with nil
--- Configuration
local temp = 'Kjøleskap'
local upper_temp_limit = 15
local lower_temp_limit = 2
local upper_temp_limit_warning_msg = "Øvre temperaturgrense " .. upper_temp_limit .. "ºC er nådd!"
local lower_temp_limit_warning_msg = "Nedre temperaturgrense " .. upper_temp_limit .. "ºC er nådd!"
--commandArray = {}
temp = tonumber(temp)
if (warning_sent == nil) then
    warning_sent = false
if (upper_temp_limit < temp and warning_sent ~= true) then
  print(upper_temp_limit_warning_msg)
  warning_sent = true
elseif (lower_temp_limit > temp and warning_sent ~= true) then
  print(lower_temp_limit_warning_msg)
  warning_sent = true
elseif (upper_temp_limit > temp and lower_temp_limit < temp) then
    print("Temp ok")
--return commandArray
Anyone se what's wrong? also, do I need the CommandArray thing? (gives the same result with and without)
zicht
Domoticz version: 2023.1+
Re: Error: EventSystem: in *event: [string " ..."]:18: attempt to compare number with nil
Post by zicht »
Just a quick view :
Is it possible that your temp is a string set in the beginning of a script to a name ?
So in the comparisation you are compairing a number with a string in the if-then ?
maybe it should be local temp = otherdevices['Kjøleskap'] to get the value of 'Kjøleskap' but thats just an assumption.
(You need to compare numbers with numbers and strings with strings.)
Evelen
Post by Evelen »
Also, another mistake was that the name of the device was wrong..
this gives me the value:
local temp_device = "29 - Kjøleskap"
local temp = tonumber(otherdevices_svalues[temp_device])
print(temp)
