Hello everyone!
I bought few RGB Light bulbs that are based on ESP8266. The come with nice firmware which enables them to be controlled with HTTP requests.
I want to make a domoticz plugin for those(python preferably). Can you give me some guidance on how to begin. I was thinking of rewriting the plugin for Yeelight but I cannot find where the plugins are stored in domoticz.
Custom RGB Light Plugin
miroslavpetrov
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
deennoo
Re: Custom RGB Light Plugin
YeeLight isn't à plugin, that à part of domoticz (github source code), and it works great for me and other, with some lua script, we can drive every thing (white temp, scène, colorflow)miroslavpetrov wrote:Hello everyone!
What is your esp8266 modules ?
http://domo-attitude.fr
miroslavpetrov
It is Shelly RGB bulb. Its firmware is based on mangoose OS. Here is an example http request:
http://192.168.1.20/color/0?turn=on&red ... 55&white=0
Can you give me some guidance how to begin with writing a LUA script or a python plugin in order to use domoticz's color picker?
Eastron SDM230
Eastron SDM230
deennoo
Colorpicker isn't on rgb but hsv, you have to use à translator if you want to use it.
On Lua you Can parse thé json value : https://www.domoticz.com/wiki/Domoticz_ ... fic_device
Another simple solution already used for hyperion plugin, or playbulb one's is to create 4. Dimmer :
Red
Green
Blue
white : if existe on your bulb
Red
Green
Blue
Dear all
There has been changes on domoticz and now the RGB color are being posted into Json, so its possible to query
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local acolor = " "
ab='curl "http://192.168.1.101:8080/json.htm?type ... '..led_idx..'"'
local jsondata = assert(io.popen(ab))
local jsondevices = jsondata:read('*all')
jsondata:close()
local jsonCPM = json:decode(jsondevices)
local acolor=jsonCPM.result[1].Color
print (acolor)
If you wish to decode the color reply from Json
acolorj=acolor:gsub("}",",}")
aacolor={}
for k,v in acolorj:gmatch('"(.-)":(.-),') do
aacolor[k]=v
print(k,v)
So you can get the RGB values in a nice table you can use later on your LUA
Hope it helps
local acolor = " "
jsondata:close()
print (acolor)
aacolor={}
aacolor[k]=v
print(k,v)
Hope it helps
- ledfreak3d
- Domoticz version: 3.8025
why do it the hard way just flash espeasy on it and use the build in support
gives you fading also problem solved
Unleashe the magic smoke ;)
