Sendheartbeat mysensors
yfands
Domoticz version: latest B
Post by yfands »
Yep I know there is already a Sendheartbeat() topic, http://www.domoticz.com/forum/viewtopic ... 5&start=20, but it is rather old and adding to the discussion a week ago did not get any replies or answers.
So hereby starting a new discussion..
Version: 3.8394
Build Hash: e9d01f6
Compile Date: 2017-09-13 08:54:08
Platform Raspberry Pi.
Hereby I would very much like to address the heartbeat function from Mysensors again, especially the V_Value option.
As stated in the following link: https://github.com/domoticz/domoticz/issues/1396 according to gizmocuz its not that easy to implement the heartbeat option, some types are implemented. I checked the latest build files and there is no change in the number of handled types. Hereby I would like to plea for an implementation of the Mysensors V_Value option. In my latest project I used a lightning detector. Who will of course only transmit when there is lightning. In between I like to know if my device is still alive (and also avoid the red widget bar (sensor timeout)), and don't have to climb every day to the attic to check on my sensor if it's still alive, so I send a heartbeat with Mysensors, unfortunately Domoticz doesn't handle V_Value heartbeats. :-(
In this case the sensors has 2 childs, lightning distance and lightning intensity, both have to be updated with the "last seen" value.
oh, and related, after a software update I always check my sensors in the setup->hardware tab. Type "MySensors Gateway USB" and clicking on the setup gives me a overview of my Mysensors sensors. And of course there is no last seen value here, and won't be till I either reset my lightning sensor (contaminating the database) or there is actual lightning.
Dear Domoticz team, can you please consider my request, I'm sure there are other builders who can appreciate the implementation.
Thanks for listening
Frank
xraken
Re: Sendheartbeat mysensors
Post by xraken »
I am also looking for this capability. My use case is for a sump pump and a couple of other z-wave water leak sensors. These sensors don't report anything until there's a leak. They also send a heartbeat every couple of hours. If any of these sensors go offline because the battery is dead (or for whatever reason) the only indication is the stopping of heartbeats. Without being able to track heartbeats there's no way to know if I'm protected from water leaks.
This should be a critical function. Please consider adding support for monitoring heartbeats for zwave water leak sensors. Thanks.
gemas
Post by gemas »
also need this. could be very handy
