Peggy wrote:- You talk about "Max!'s own web based configuration tool". You did'nt talk about max!buddy. I'm a bit confused, I thought this one was mandatory as a gateway between max! cube and domoticz
No, max!buddy is not necessary anymore, my scripts (based on the work of others) communicate directly with the Cube.
Peggy wrote:- You talk about a crontab script, but I'm under windows, I don't know if it is possible to set up a crontab in windows.
Oops, you mentioned that, forgot about that. It is possible, using Windows Task Scheduler. Simply add a task that runs every 5 minutes, starting my script from Lua. The command that is started would be something like "c:\program files\lua\lua.exe c:\program files\Domoticz\scripts\lua\maxscript.lua" (first install Lua for Windows). I haven't tried it, it should work but if you're not so familiar with these things it could be a bit complex. Another solution is to use the standard lua script, as explained a number of posts earlier. That scenario requires you to manually create dummy devices with exactly the right names for each Max! device you have.
Peggy wrote:- About the wall thermostat, I can get the max! one for 27€, so the price is ok. But I already have a temp sensor in the most important rooms (I have 4 bedroom, 2 verandas, 2 living room, 2 kitchen, 2 bathrooms etc.), and a home made custom touch screen in the living room that will evolve with heating control options in the future (see picture under). I you think that a max thermostat brings better comfort (for instance changing temperature), I'm listening to you (you talked about manual override, this is a good reason, but I have so many rooms...).
You can do without. If it's just for setting thermostat setpoints on certain times or depending on certain events, then you don't need them, and it's probably best to not even create the temperature device for each radiator valve within Domoticz (as it gets updated so irregularly). Just use the Domoticz thermostat devices for each valve, and program whatever timer or (blockly) script you want for them. You can add setpoint control functionality to your (beautiful!) touch screen, even nicer than the wall mounted thermostats!
(By the way, I have both: wall mounted thermostats in two bedrooms, plus a wall mounted tablet in the living room that can also control the setpoints. I prefer this solution because I want to make it as easy as possible for the users of those rooms to control things, it all adds to the WAF
. My son can change the setpoint of his room to whatever he wants, whenever he wants, but it always gets reset at night and when leaving home, or when he leaves his door or window open.)
