Notification if power consumption is too high
Slinkos
Domoticz version: 3.4834
Post by Slinkos »
Hi all, I am tryting to find a solution for the following:
If the amound of electricity I'm using is above a certain kWh , for more than 10 minutes, I want to be notificated.
How can I do that? I tought to make a dummy switch with a delay. But when the power is above the amound of kwh, the delayed switch will go on, even if after the 10 minutes the kwh is at a normal point again.
I would also like to do a similair thing with my door sensor. If the door is open for more than 5 minutes or so, I want to be notificated.
mrf68
Re: Notification if power consumption is too high
Post by mrf68 »
create a dummy switch that turns on when using more than x kWh and turns of when using less. Check every minute (script_time) if the switch is on and when it last updated its status. When it's more than 10 minutes, then send a notification.
Same goes for the door contact. Get the difference between current time and last update, if more than 10 minutes and contact is open then send message.
Slinkos
Post by Slinkos »
Thanks that's a great solution! Didn't think of that.
Is there by any chance an example of a script_time script? I didn't use that before.
mrf68
Post by mrf68 »
Sure, you can find it in the WiKi:
https://www.domoticz.com/wiki/Event_script_examples
Slinkos
Post by Slinkos »
Thanks I got it working now!
