Hi!
I connected a NRF24L01 on the GPIO of my RaspBerry Pi 3B, using this page:
https://www.raspberrypi.org/magpi/pi-mi-light/
It all seems to be connected correctly, but whatever I do with my Mi-Light, nothing is detected when in listening mode. When I run a test with another program/script, it shows no errors if communicating with the NRF24L01, when all is connected and shows an error when I disconnect a wire.
I use the 2,4Ghz WiFi iBox to control the lights through the Mi-Light app and that works like it is supposed to.
The NRF24L01 should pick up the signal from the iBox right? Or only from the remote control, which I don't have.
Any thought are very welcome.
With kind regards,
Martijn
NRF24L01 on GPIO
SweetPants
Re: NRF24L01 on GPIO
What's the relation to domoticz?
I have read that the NRF24 module needs a very stable 3.3v or add a 10uF capacitor accross the powersupply lines of the chip
Thelion
- Domoticz version: 2022.1
Hi Sweetpants,
The relation to Domoticz is that I want to use Domoticz with the NRF24 to control my Mi-Light lighting.
A capacitor. Interesting. Never saw anything regarding a capacitor. Will try that. Thanks!
You may need a voltage regulator too if are using max power
- Marci
- Domoticz version: 3.8153
No problem there. You have warnings (which are just that and can be ignored) but no errors.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
- cyberclwn
- Domoticz version: 2024.4
Hey,
From the website you linked:
... then press the On button for Zone 1 on the remote a couple of times. ...
I think there is the problem...
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
