Python Plugin: Wan IP Checker
poudenes
Domoticz version: 3.8993
Re: Plugin - Wan IP Checker
Post by poudenes »
when this error pop up it also let crash other python scripts. Need to restart Domoticz to let it run ok again
ycahome
Domoticz version: lat Beta
Post by ycahome »
poudenes wrote: Wednesday 30 August 2017 9:31 Works GREAT !!!!!
Only thing: You can not use it on a Slave Domoticz and read the info on the Master Domoticz. The Device is not shown in list of "not used"devices on the Master Domoticz.
Maybe thats it thing to look at. Rest briljant plugin. Now i can check if my VPN is on !!
This depends on which type of devices/switches are allowed to be remotely transferred from Domoticz. This is not something that can be defined from plugin itself.
br,
ycahome
Post by ycahome »
#1st Post Updated with the new version.
-Improve: Timeout added to prevent stale url requests.
EdwinK
Post by EdwinK »
Used to work earlier today (no error seen), but by change I looked at the error-log tonight and noticed this
2017-09-15 22:11:30.547 Error: IP Check hardware (38) thread seems to have ended unexpectedly
ycahome
Post by ycahome »
EdwinK wrote: Friday 15 September 2017 22:17 Used to work earlier today (no error seen), but by change I looked at the error-log tonight and noticed this
Strage, did you change to new version (1.1.0)? or you still have the previous one?
Can you give more details?
EdwinK
Post by EdwinK »
Used the latest version, running on Synology.
Dnpwwo
Post by Dnpwwo »
@EdwinK,
You will see this in the log if the plugin Heartbeat is ever greater than (or equal to) 30 seconds because Domotoicz doesn't like it.
The plugin will work just fine, that is just a warning.
EdwinK
Post by EdwinK »
Thanks. Will ignore it then.
Teknor
Domoticz version: 3.48
Post by Teknor »
When installing the plugin I get the following error and Domoticz will not start. Kind of strange that my GPIO export settings will make the script fail?
All help is appreciated. Thanks.
pi@raspberrypi:~/domoticz/plugins $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh)
   Active: active (exited) since sø. 2017-10-29 21:37:23 CET; 3min 7s ago
  Process: 576 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
okt. 29 21:37:23 raspberrypi sudo[861]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh -c echo 27 > /sys/class/gpio/export
okt. 29 21:37:23 raspberrypi sudo[861]: pam_unix(sudo:session): session opened for user root by (uid=0)
okt. 29 21:37:23 raspberrypi sudo[861]: pam_unix(sudo:session): session closed for user root
okt. 29 21:37:23 raspberrypi sudo[874]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh -c echo high > /sys/class/gpio/gpio27/direction
okt. 29 21:37:23 raspberrypi sudo[874]: pam_unix(sudo:session): session opened for user root by (uid=0)
okt. 29 21:37:23 raspberrypi sudo[874]: pam_unix(sudo:session): session closed for user root
okt. 29 21:37:23 raspberrypi sudo[886]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sh -c echo 1 > /sys/class/gpio/gpio27/active_low
okt. 29 21:37:23 raspberrypi sudo[886]: pam_unix(sudo:session): session opened for user root by (uid=0)
okt. 29 21:37:23 raspberrypi sudo[886]: pam_unix(sudo:session): session closed for user root
okt. 29 21:37:23 raspberrypi systemd[1]: Started LSB: Home Automation System.
Raspberry Pi 3 | EasyESP NodeMCU v3 | RFXTRX433e | Mysensors NRF24L01 | MotionEYE | PikrellCam
manjh
Post by manjh »
I installed this following the instructions. Logged in and then did sudo su.
Created the plugin.py in a new subdir under "plugins".
Restarted Domoticz. No errors, but I don't see the WAN checker in the hardware setup dropdown...
Hans
ycahome
Post by ycahome »
manjh wrote: Sunday 28 January 2018 18:46 I installed this following the instructions. Logged in and then did sudo su.
Hi there.
Do you have any other python plugins?
D you have python properly installed?
manjh
Post by manjh »
ok
tell me how to check pls.
Hans
ycahome
Post by ycahome »
manjh wrote: Sunday 28 January 2018 22:34 ok
# from https://www.domoticz.com/wiki/Using_Python_plugins
# install dependencies
sudo apt-get install -y python3
# Domoticz Beta versions since V3.6129 also require...
sudo apt-get install -y python3-dev
manjh
Post by manjh »
ycahome wrote: Monday 29 January 2018 8:30
OK, this tells me how to install. But how can I check if it is already installed or not?
Hans
ycahome
Post by ycahome »
manjh wrote: Monday 29 January 2018 13:04
if you try to install, you will be prompted when the package is already installed.
manjh
Post by manjh »
Sure enough: that second install did it. I can now add the IP checker in the HW tab. Thanks!
Hans
domoticzag
Post by domoticzag »
Thanks for the plugin, and thanks to the creator :D works great!
Now I would like to do one thing with this script, send myself an email when the WAN IP changes :D, of course, with the IP in the message.
Now I have created this script:
But this is the result:
Anyone know how I can get the correct utility value in the email/notification?
RPi 3
Domoticz Béta
RFLink Gateway dipool antenna
Many kaku devices
P1 smart meter
Custom made ESP8266 devices
Hue lights / Milight ligts and strips
manjh
Post by manjh »
domoticzag wrote: Monday 29 January 2018 18:22 Thanks for the plugin, and thanks to the creator :D works great!
I have done exactly that today! Even made sure I only receive one e-mail per day. Otherwise you may wake up with a mailbox full of warnings..
The only thing is: It is not in Blockly, but in LUA. If you have the courage to get into LUA, I can post my small LUA script here...
Hans
domoticzag
manjh wrote: Monday 29 January 2018 18:48
It may post several times an hour, but only if the WAN does actually change, thats why I made the user variable. But I dont understand why this doesnt work, even when I email the utility it just saids utility(358) instead of the actual value.
But if you could post it, I would much appreciate !
It would actually be smoother to integrate this functionality into the Plugin itself. I would need to do some Python exercises first, I am an experienced C programmer but this is just a little bit different.
RPi 3
Domoticz Béta
Many kaku devices
P1 smart meter
manjh
Post by manjh »
You could have the e-mail script triggered by a change in the text device: once the WAN address changes, the plugin will change the text and it would then trigger the mail. Probably. It makes the whole mechanism somewhat easier, and it will result in one single e-mail after a change of the WAN address. But I want to have one mail per day, in case I miss a warning mail. It will keep sending the daily mail, until I have changed my DNS entry and also stored the new IP address in my user variable.
My script works like this: I store the currently known WAN address in a user variable, and check that. If it changes, I compose and send an e-mail, and store the date in another user variable. The next time I want to send an email, I check the date: if it is the same I donot send. This way I only get one single warning message per day.
Code dependency:
two user variables (type string):
"WAN IP" contains the last known WAN IP address
"WAN IP Warning sent" contains the date on which a warning was sent (to make sure one warning is sent per day, not more/less)
one text device, as created by the plugin, named "WAN IP".
-- This script will periodically check if the WAN IP is changed
-- get stored WAN IP address
VAR_IP = uservariables['WAN IP']
-- get current WAN IP address
WAN_IP = otherdevices_svalues['WAN IP']
-- check if current WAN IP address has changed
if (VAR_IP ~= WAN_IP) then
    -- check if warning was already sent today
    curr_date = os.date('%Y-%m-%d')
    sent_date = uservariables['WAN IP Warning sent']
    if (sent_date ~= curr_date) then
        print ("Warning! WAN IP has changed!")
        -- compose text for warning e-mail
        Subject = "WAP IP address has changed"
        Body = " The WAN IP address in De Meern seems to have changed. Previous address was "..VAR_IP..". Current address is "..WAN_IP..". Please check, and change the DNS entry at Hostnet."
        -- send warning e-mail to admin (address is stored in uservariable AdminMail)
        commandArray['SendEmail'] = Subject .. "#" .. Body .. "#" .. uservariables['AdminMail']
        -- store current date to indicate warning has been sent
        commandArray['Variable:WAN IP Warning sent'] = curr_date
    -- clear warning sent field, if necessary
    if (uservariables['WAN IP Warning sent'] ~= ".") then
        commandArray['Variable:WAN IP Warning sent'] = "."
Hans
