LAU to read barometer at x:20
starfish001
Post by starfish001 »
i would like to run a time based script to read a barometer from a Esp8266 sensor every hour not sure how to read the sensor
time = os.date("*t")
mtAT = devicechanged_svalues['ESPO_bar']
print('####TEST DEBUG: '.. mtAT)
jvdz
Domoticz version: 4.107
Re: LAU to read barometer at x:20
Post by jvdz »
What do you mean with: "not sure how to read the sensor"? Is the sensor data already available in Domoticz?
If so then the devicechanged_svalues[] table is wrong as that table doesn't exists (see here). You need to use the otherdevices_svalues[] table.
To execute the logic only one time each hour you could do:
-- Time to run?
if (time.min == 0) then
   mtAT = otherdevices_svalues['ESPO_bar']
Jos
starfish001
sorry - I have an esp8266 set-up as a sensor sending data into Domoticz every few minutes into a virtual sensor. I wanted to setup alerting. Blocky can do it but it is not very neat so I just wanted to create a timed notification to take the value from the virtual sensor and then create the alert.
Your suggested code snipet fixed my issue perfectly :D
if time.min == 47 then
espBarReading = otherdevices_svalues['ESPO_bar']
print('####TEST DEBUG Barometer Reading:: '.. espBarReading)
commandArray['SendNotification']='Barometer Reading: '.. espBarReading
