I've bought some Sonoff devices and have flashed Tasmota to utilise MQTT.
Following the Domoticz MQTT wiki I have added the MQTT Client Gateway with LAN interface
https://www.domoticz.com/wiki/MQTT
The wiki indicates that all the necessary software is installed with the Domoticz image
But I see this error:Please note that the current Domoticz SDCard image has this included, and you do not need to install any software.
MQTT: Failed to start, return code: 14 (Check IP/Port)
Is it possible my install is old enough that MQTT was not on the image?
What do I need to do to get MQTT running?
Many thanks!
Version V3.8392
Raspberry Pi
