Create new User variable event and cut and paste the following script
-- This script is used to send Messages to Enigma2 boxes
-- This script will trigger on any uservariables being changed
-- Place messages in string User variable EnigmaMessage
-- Once sent message will be removed from EnigmaMessage
-- If not running Enigma Scan remove Fuction split, table Vars and amend variable Ip to be the IP address of Enigma2 box
-- Note to trigger switch Uservarible must be triggered by external Program or use Switch-Link
-- Version 1.0
-- Setup Variables
-- Set functions
function split(pString, pPattern)
local Table = {}
local fpat = "(.-)" .. pPattern
local last_end = 1
local s, e, cap = pString:find(fpat, 1)
while s do
if s ~= 1 or cap ~= "" then
table.insert(Table,cap)
last_end = e+1
s, e, cap = pString:find(fpat, last_end)
if last_end <= #pString then
cap = pString:sub(last_end)
table.insert(Table, cap)
return Table
-- Set Variables
-- Remove following two lines if not running Enigma-Scan
-- REplace with ip = "ip of Enigma 2 box"
Vars = split(uservariables["EnigmaParams"],"|")
ip = Vars[1]
message = uservariables["EnigmaMessage"]
-- Start Program
print("Start Enigma Message")
if message ~= nul then
url = ("http://" .. ip .. "/web/message?text=" .. message .. "&type=1&timeout=15")
url = string.gsub(url, " ", "%%20")
commandArray[1]={["OpenURL"] = url}
message = ""
commandArray[2]={["Variable:EnigmaMessage"] = message}
The script will only be called when the User variables updates. This is normally from an external programs via Json. Updating from commandarray or from within Domoticz will not trigger User Variable scripts . However I have also written script-link which allows you to link switches to User variables which will trigger scripts see
viewtopic.php?f=38&t=19217
For set messages on switches you could also use the http notification option see
viewtopic.php?f=4&t=13217&p=124071&hili ... a2#p124071
Hope this proves useful
