Hey, Thanks.Egregius wrote: Saturday 12 August 2017 17:35 Hi Simon,
The code at github should be pretty recent, will update it in a few minutes with my latest code and scripts.
The installation in the wiki should be a good starting point, not very detailed...
https://github.com/Egregius/LUA-Pass2PH ... stallation
I tried to run
sudo apt-get install php7.0 php7.0-cgi php7.0-common php7.0-fpm php7.0-json php7.0-mysql php7.0-phpdbg php7.0-sqlite3 php-apcu php-common php7.0-bcmath php7.0-cli php7.0-curl php7.0-gmp php7.0-mbstring php7.0-opcache php7.0-readline php7.0-xml php-cgiCode: Select all
pi@raspberrypi:~$ sudo apt-get install php7.0 php7.0-cgi php7.0-common php7.0-fpm php7.0-json php7.0-mysql php7.0-phpdbg php7.0-sqlite3 php-apcu php-common php7.0-bcmath php7.0-cli php7.0-curl php7.0-gmp php7.0-mbstring php7.0-opcache php7.0-readline php7.0-xml php-cgi
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package php7.0
E: Couldn't find any package by regex 'php7.0'
E: Unable to locate package php7.0-cgi
E: Couldn't find any package by regex 'php7.0-cgi'
E: Unable to locate package php7.0-common
E: Couldn't find any package by regex 'php7.0-common'
E: Unable to locate package php7.0-fpm
E: Couldn't find any package by regex 'php7.0-fpm'
E: Unable to locate package php7.0-json
E: Couldn't find any package by regex 'php7.0-json'
E: Unable to locate package php7.0-mysql
E: Couldn't find any package by regex 'php7.0-mysql'
E: Unable to locate package php7.0-phpdbg
E: Couldn't find any package by regex 'php7.0-phpdbg'
E: Unable to locate package php7.0-sqlite3
E: Couldn't find any package by regex 'php7.0-sqlite3'
E: Unable to locate package php-apcu
E: Unable to locate package php-common
E: Unable to locate package php7.0-bcmath
E: Couldn't find any package by regex 'php7.0-bcmath'
E: Unable to locate package php7.0-cli
E: Couldn't find any package by regex 'php7.0-cli'
E: Unable to locate package php7.0-curl
E: Couldn't find any package by regex 'php7.0-curl'
E: Unable to locate package php7.0-gmp
E: Couldn't find any package by regex 'php7.0-gmp'
E: Unable to locate package php7.0-mbstring
E: Couldn't find any package by regex 'php7.0-mbstring'
E: Unable to locate package php7.0-opcache
E: Couldn't find any package by regex 'php7.0-opcache'
E: Unable to locate package php7.0-readline
E: Couldn't find any package by regex 'php7.0-readline'
E: Unable to locate package php7.0-xml
E: Couldn't find any package by regex 'php7.0-xml'
E: Unable to locate package php-cgi
