attempt to call field 'after_min' (a nil value)
DannyElfman
Domoticz version: 3.8136
Post by DannyElfman »
Quick question. I am very new to LUA and dzVents. I have a simple script generating a classic nil value error but I just cannot get why I have this error ...
Basically, when my squeezebox is playing, it switches on a sonoff connected to my subwoofer.
Script :
      active = true, -- set to false to disable this script
        devices = {
            -- scripts is executed if the device that was updated matches with one of these triggers
            368, -- id Squeezebox
        local caisson = domoticz.devices(527) -- sonoff caisson
        local musique = domoticz.devices('Squeezebox')
        if (device.state == 'Off') then
            caisson.switchOff()
        elseif (device.state == 'Stopped') then
            caisson.switchOff().after_min(10)
            musique.switchOff().after_min(10)
            caisson.switchOn()
switchOn works fine.
switchOff too
From the log :
2017-09-07 08:12:33.083 dzVents: Info: ------ Start internal script: Caisson_Musique: Device: "Squeezebox (Logitech Media Server)", Index: 368
2017-09-07 08:12:33.083 Error: dzVents: Error: An error occured when calling event handler Caisson_Musique
2017-09-07 08:12:33.083 Error: dzVents: Error: ...cz/scripts/dzVents/generated_scripts/Caisson_Musique.lua:40: attempt to call field 'after_min' (a nil value)
2017-09-07 08:12:33.083 dzVents: Info: ------ Finished Caisson_Musique
Any idea would be really appreciated :)
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
elmortero
Domoticz version: 3.9639
Re: attempt to call field 'after_min' (a nil value)
Post by elmortero »
Please check http://www.domoticz.com/forum/viewtopic ... 59&t=18674 which has the info you need.
Hint: you are using the old dzVents manual, some things have changed.
Your answer is in the part about migrating to the new version.
DannyElfman
Well, first thanks for taking the time to answer me.
Then thanks for spotting it out :)
I had printed the doc a month and a half ago cause I find it easier to read ... I forgot the update issue ^^
I have updated my script. I did not checked yet if it is working but I will and get back to you.
For those interested, the issue was indeed in the timed command which has to be updated with :
caisson.switchOff().afterMin(10)
