I have LogoControl installed in my RPI to control my siemens logo plc and now i want to get status from LogoControl to domoticz and use dzVents to control my plc.
I can check status with rest/json calls and looks like this example:
turn On = https://LogoControl:8088/rest/devices/1/methods/1
turn Off = https://LogoControl:8088/rest/devices/1/methods/2
check status = https://LogoControl:8088/rest/devices/1 ... es/1/value
(1=On 0 = Off)
any Ideas how to check status in dzVents?
// DewGew
Get status from LogoControl for Siemens Logo PLC
- DewGew
- Domoticz version: V4.10618
- DewGew
Re: Get status from LogoControl
Maybe I can use this
How do I read the resultfile then?
//DewGew
os.execute('curl -s "'..url..'" > /tmp/resultfile&')
//DewGew
It's not really specific for dzVents. It's more a Lua question.DewGew wrote: ↑Wednesday 06 September 2017 11:01 Maybe I can use thisHow do I read the resultfile then?Code: Select all
//DewGew
Putting a command in the background to execute and get back later to check the results that has been stored in a file can be a good option if requesting an URL over the Internet. Doing it that way won't introduce delays in the Domoticz event queue in case the server takes time to respond. With that being said, if it's a local server in your LAN that's always available and answers fast you should read the result when doing the request. E.g. local result=assert(io.popen(url)). That method should be avoided though if going outside your LAN. There are several other scripts using this method that you can use as a starter. But again, it's not a specific dzVents question.
Cheers!
- DewGew
Now I have LogoControl by http://www.frickelzeugs.de working with a dzVents script. I share it here if anyone is interested or maybe someone can build a python plugin.
LogoControl.lua
Feel free to modify this code
//DewGew
LogoControl.lua
-- LogoControl script v1.0.0 --
by DewGew
dzVents script to control and monitor Siemens Logo PLC 0Ba7 or OBa8 using
LogoControl by frickelzeugs as a bridge between domoticz and PLC.
LogoControl download and manual: http://www.frickelzeugs.de/
Control Domoticz devices thrue LogoControl I use shell script within LogoControl.
./home/pi/LogoControl/Scripts/yourscriptfile.sh
Switch Device 123 on or off:
#!/bin/bash
ip=127.0.0.1
port=8080
switchidx=123
curl "http://$ip:$port/json.htm?type=command¶m=switchlight&idx=$switchidx&switchcmd=On"
or
curl "http://$ip:$port/json.htm?type=command¶m=switchlight&idx=$switchidx&switchcmd=Off"
then add 'trigger' in your LogoControl config file, example on PLC output Q1 (device 1 in LogoControl):
<device id="1" name="Bedroom Light" type="light">
<attribute id="1" name="Status" plc="myLogo" address="Q1" valueTextConverter="on_off" />
<method id="1" name="on" plc="myLogo" address="150.0" script="Q1_on.sh" />
<trigger plc="myLogo" address="150.0" datatype="bit">
<onValue value="1" method="1" />
</trigger>
<method id="2" name="off" plc="myLogo" address="150.1" script="Q1_off.sh" />
<trigger plc="myLogo" address="150.1" datatype="bit">
<onValue value="2" method="2" />
</trigger>
</device>
Titel: logoControl.lua
Framework: dzVents 2.2.0
Datum: 2017-09-14
active = true,
devices = {
'Q1', -- Add domoticz devices that will trigger the script
'Q2',
-- 'Q3' -- etc
logging = {
level = domoticz.LOG_DEBUG,
marker = "LogoControl script: " -- prefix added to every log message
local logoControlIP = "127.0.0.1" -- LogoControl Ipadress
local logoControlport = "8088" -- LogoControl Port
local logoControlDeviceNr = ""
local logoControlDeviceAttrNr = ""
if device.name == "Q1" then logoControlDeviceNr = 1 end -- pair domoticz device with LogoControl device
if device.name == "Q1" then logoControlDeviceAttrNr = 1 end -- pair domoticz device with LogoControl device Attribute eg. table at http://logocontrol:8088/rest/attributes (on/off status or value)
if device.name == "Q2" then logoControlDeviceNr = 5 end
if device.name == "Q2" then logoControlDeviceAttrNr = 6 end
-- if device.name =="Q3" then logoControlDeviceNr = 3 end -- etc.
-- if device.name =="Q3" then logoControlDeviceAttrNr = 3 end
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local file=assert(io.popen('curl http://' .. logoControlIP ..':' .. logoControlport .. '/rest/attributes'))
local raw = file:read('*all')
file:close()
local logoControlAttributes = json:decode(raw)
local logoOutputDevice = logoControlAttributes.attributeUpdates[logoControlDeviceAttrNr].D
local logoOutput = logoControlAttributes.attributeUpdates[logoControlDeviceAttrNr].V
local logoOutputText = logoControlAttributes.attributeUpdates[logoControlDeviceAttrNr].T
domoticz.log('Checking status -- Device ' .. logoOutputDevice .. ' status is ' .. logoOutput .. ' (' .. logoOutputText .. ')', domoticz.LOG_INFO)
if device.state == 'On' and logoOutput == 0 then
domoticz.openURL('http://' .. logoControlIP .. ':' .. logoControlport .. '/rest/devices/' .. logoControlDeviceNr .. '/methods/1')
domoticz.log('Switching on domoticz device ' .. device.name .. ' and LogoControl device ' .. logoControlDeviceNr,domoticz.LOG_INFO)
elseif device.state == 'Off' and logoOutput == 1 then
domoticz.openURL('http://' .. logoControlIP .. ':' .. logoControlport .. '/rest/devices/' .. logoControlDeviceNr .. '/methods/2')
domoticz.log('Switching off domoticz device ' .. device.name .. ' and LogoControl device ' .. logoControlDeviceNr,domoticz.LOG_INFO)
//DewGew
Re: Get status from LogoControl for Siemens Logo PLC
Hi DewGew,
Finaly got the time to connect Domoticz to my logo's, switching worksfine however I can't get the status of the output in Domoticz.
Can you please help me with your script? I uploaded as a dzVents to domotics and adjusted the logocontrol IP and port settings.
Maybe I'm missing something small, but I can't figure it out.
