Hi guys,
I just bought Roowifi, it allow to connect to Roomba vacuum cleaner via Wifi. There is also possible to read sensor status and remote control Roomba. I'm not programmer and I'm able only to start CLEAN and other two commands trough AJAX command. So I would like to ask if somebody wold be sou kind and implement Roowifi into Domoticz. API is completely described on http://www.roowifi.com/roowifi-api-11b/. It is already implemented into other home automation systems http://www.roowifi.com/home-automation/.
Roowifi - Roomba vacuum cleaner
Re: Roowifi - Roomba vacuum cleaner
Hi, where did you buy tb roowifi? I can't find it in internet. Thanks
Enviado desde mi iPhone utilizando Tapatalk Pro
Roowifi says it clearly on their website.
Check out this once and sure it will helps you:
http://www.roowifi.com/wifi/
