- Domoticz version: 2024.7
Screensaver
Try to configure a screensaver in Dashticz on my tablet at the wall.
syntax in the wiki:
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
This syntax gives results! After a while there is a screensaver. I don't understand the other syntax in my config.js:
config['standby_after'] = 3;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '15';
config['auto_slide_pages'] = 0;
Can you explain these commands to me? Thnx in advance.
syntax in the wiki:
Synology with Domoticz build (V2024.7) in Docker
- Domoticz version: 3.8153
Hello, is possible change a position in the buienradar to Czech Republic?
Odesláno z mého MI 4W pomocí Tapatalk
- EdwinK
- Domoticz version: BETA
I don't think so. Buienradar is aimed at the Netherlands.
- Phantom
- Domoticz version: 4.11652
The website is in dutch but maybe this link will help you a bit: https://www.buienradar.nl/wereldwijd/eu ... d/tsjechie
At the bottom you can insert a city.
- htilburgs
Re: Screensaver
Al these syntaxes are explained in the Wiki: http://www.domoticz.com/wiki/Dashticz_V ... figuration
Standby option:
Standby option:
These are not standby options. You can let Dashticz automatic swipe between your screens, if you've multiple screensconfig['standby_after'] - [MINUTES] - Enter the amount of minutes before entering stand-by mode
config['auto_swipe_back_to'] - [SCREEN NR]- When no activity, swipe back to the selected screen
config['auto_swipe_back_after'] - [SECONDS] - Define the seconds after swiping back to the selected screen
config['auto_slide_pages'] - false / [SECONDS] - Loop all pages and change page every x (min. 5) seconds, set config['auto_swipe_back_after'] = 0
Hardware:
- htilburgs
Re: Screensaver
Al these syntaxes are explained in the Wiki: http://www.domoticz.com/wiki/Dashticz_V ... figurationPieterS wrote: ↑Saturday 02 September 2017 21:40 Try to configure a screensaver in Dashticz on my tablet at the wall.
syntax in the wiki:
Standby option:
Hardware:
Sorry for my omission! I missed that paragraph.Al these syntaxes are explained in the Wiki: http://www.domoticz.com/wiki/Dashticz_V ... figuration
Thanks a lot for your hint.
- htilburgs
I hope you succeed! Otherwise we see you back soon and we will try to help youPieterS wrote: ↑Monday 04 September 2017 21:59Sorry for my omission! I missed that paragraph.Al these syntaxes are explained in the Wiki: http://www.domoticz.com/wiki/Dashticz_V ... figuration![]()
Hardware:
I just got Dashticz beta up and running and changed some settings via the "gear" configuration button in the upper right corner. I hid the title bar and now it and the the configuration button are gone.
I've tried this in CONFIG.js, but the top bar and config button are still missing.
config['hide_topbar'] = '0';
How can I get these back?
I just started with Dashticz and noticed that, by default, all settings in the CONFIG.js are 'commented out' by the /* and */ character codes. If these appear at the top and bottom of your CONFIG.js file then remove these and try again...godomogo wrote: ↑Tuesday 05 September 2017 15:34 I just got Dashticz beta up and running and changed some settings via the "gear" configuration button in the upper right corner. I hid the title bar and now it and the the configuration button are gone.
Yeah, I think this would be awesome to be able to put existing floorplans in screens[x]. Another option people might like is a button.floorpan setup to pop up a window/frame.
Turns out I had some syntax errors elsewhere in CONFIG.js. That's all fixed and this is looking GREAT!Douwe63 wrote: ↑Tuesday 05 September 2017 20:56I just started with Dashticz and noticed that, by default, all settings in the CONFIG.js are 'commented out' by the /* and */ character codes. If these appear at the top and bottom of your CONFIG.js file then remove these and try again...godomogo wrote: ↑Tuesday 05 September 2017 15:34 I just got Dashticz beta up and running and changed some settings via the "gear" configuration button in the upper right corner. I hid the title bar and now it and the the configuration button are gone.
- Domoticz version: 3.7067
Added the floorplan to github...
Unfortunately, I'm on vacation until 23th of september so wont be working on this before this date.
(And I have first some other things to fix)
- Domoticz version: Latest
Dashticz - Two Questions
Got two questions for Dashticz.
First, i can't seem to figure out how to add scene's to Dashticz. It just don't sees them. Checked the IDXes and everything. This is the block i use:
Am i doing something wrong?
Second, i want to add two push-on buttons, the normal IDX buttons are added but as soon as i add these two it won't work. Do you have any idea why?
For example this is the JSON data:
Regards, Paul
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Scenes';
blocks['s1'] = {}
blocks['s1']['width'] = 2; //1 to 12, remove this line if you want to use the default (4)
blocks['s1']['title'] = 'Living room' //if you want change the name of switch different then domoticz
blocks['s6'] = {}
blocks['s6']['width'] = 2;
blocks['s4'] = {}
blocks['s4']['width'] = 2;
blocks['s3'] = {}
blocks['s3']['width'] = 2;
blocks['s2'] = {}
blocks['s2']['width'] = 2;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s2','s3','s4']
columns[1]['width'] = 2;
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "On",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"HardwareName" : "Dummy Switches",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0001408B",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-07-01 21:56:25",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Thuis",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "59"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"ID" : "0001408C",
"Image" : "Light",
"LastUpdate" : "2017-05-20 16:45:49",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Weg",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "60"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"ID" : "0001408D",
"Image" : "Light",
"LastUpdate" : "2017-05-16 14:10:59",
"Level" : 100,
"LevelInt" : 100,
"Name" : "Nacht",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "61"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "On",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 8,
"ID" : "0001408E",
"Image" : "Light",
"LastUpdate" : "2017-06-27 22:01:54",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Manual",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "62"
Regards, Paul
This is our world now... the world of the electron and the switch, the beauty of the baud.
Re: Dashticz - Two Questions
As far as i can see yes.
- HansieNL
Maybe you can post your config.js? Are you using stable or beta version of Dashticz?
Blah blah blah
Surething! Using the one from GIT Hub, downloaded it this week.
var _EDIT_MODE = false;
var config = {}
config['domoticz_ip'] = 'http://192.168.2.253:8080';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_after'] = '10';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['language'] = 'en_US';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = '---masked---';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = '---masked---';
config['gm_zoomlevel'] = '10';
config['gm_latitude'] = '52.497911';
config['gm_longitude'] = '4.959753';
config['wu_api'] = '---masked---';
config['wu_city'] = 'Purmerend';
config['wu_name'] = 'Weer Purmerend';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 1;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 1;
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var calendars = {}
calendars.private = { key:'private', width:6, maxitems: 4, icalurl: '---masked---' }
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'purmerend/bushalte-bovenlandsestraat', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var maps = {}
maps.purmerend = { key:'purmerend', height: 300, link:'http://www.ovzoeker.nl', width:12, latitude: 52.497911, longitude: 4.959753, zoom:9 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.buienradar = { key: 'buienradar', width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Purmerend/4058348'}
buttons.tweakers = {key: 'tweakers', width:12, icon: 'fa-newspaper-o', title: 'Tweakers', url: 'https://www.tweakers.net'}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
buttons.domoticz = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
//buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
//buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['s1'] = {}
blocks['s6'] = {}
blocks['s4'] = {}
blocks['s3'] = {}
blocks['s2'] = {}
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://cors-anywhere.herokuapp.com/http://www.nu.nl/rss/Algemeen';
blocks['news_1']['maxheight'] = 113;
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://cors-anywhere.herokuapp.com/http://feeds.feedburner.com/tweakers/nieuws';
blocks['news_2']['maxheight'] = 113;
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',publictransport.ovinfobus,calendars.private]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [buttons.buienradar,'sunrise','stationclock',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
columns[8] = {}
columns[8]['blocks'] = [buttons.domoticz,'sunrise']
columns[8]['width'] = 2;
buttons.moon = {width:6, isimage:true, refreshimage:60000, image: 'moon'}
columns[5] = {}
columns[5]['blocks'] = [buttons.buienradar, buttons.nunl, buttons.radio, buttons.moon]
columns[5]['width'] = 4;
columns[6] = {}
columns[6]['blocks'] = ['traffic','train',maps.purmerend]
columns[6]['width'] = 5;
columns[7] = {}
columns[7]['blocks'] = ['log','news_1','news_2']
columns[7]['width'] = 5;
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['columns'] = [5,6,7]
- HansieNL
I'm not sure, but Maybe you can change both to 0 and see if that solves your problem
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
If you don't see your other switches you have to create these as blocks. You can find how to do that in the wiki.
Blah blah blah
