Can you pm me a viewer account with your remote settings so i can debug?Bandbox wrote: ↑Saturday 02 September 2017 19:55 All,
First of all, a great app and purchased it directly. Personally, I find this app better than Pilot. The look and feel is much better. My compliments!
I do have one issue with this app. Although I am using the same credentials for remote access for address, port, etc, I am not able to control my switches. With Pilot it worked great, so I am sure my port forwarding in my router is correct. Via WiFi the Domoticz app work great, but not without WiFi.
Plz your guidance.
Thx Anton
Domoticz App
- galadril
- Domoticz version: latest
Re: Domoticz App
- Domoticz version: 3.8993
Re: Domoticz App
I use the settings out of the box of Domoticz install.galadril wrote: ↑Saturday 02 September 2017 19:02Do you use self signed certificates on https?? If so, please use proper certificate authority to sign the certificates (can be free like Let's Encrypt).
Else, please give me a view-account on your system, so I can debug why you can't connect..
Thanks for the feedback!
- Domoticz version: 3.8153
Re: Domoticz App
Hi Galadril,galadril wrote: ↑Saturday 02 September 2017 19:56Can you pm me a viewer account with your remote settings so i can debug?Bandbox wrote: ↑Saturday 02 September 2017 19:55 All,
Plz your guidance.
Thx Anton
Thx for the swift response. I would like to sent a PM, however I am receiving the message "We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature." What can I do about this?
Furthermore, are you referring to a viewer account on my Domoticz or would you like to receive screenshots of the remote settings incl port forwarding rules?
Thx Anton
Re: Domoticz App
This is looking to be a great app.
I'm a Xamarin developr so i know a bit about developing apps, maybe i can help out sometime.
Anyway.
I bought the app because i would like to use the notifications. But, i cant seem to get this to work.
I have the latest BETA version of Domoticz running with GCM enabled. But i get an error.
How can we fix this?
Anyway.
2017-09-03 21:34:28.085 Error: GCM: Could not send message, HTTP Error.
2017-09-03 21:34:28.086 Error: Notification sent (gcm) => Failed
2017-09-03 21:34:28.100 Active notification Subsystems: gcm (1/12)
- galadril
Re: Domoticz App
There are issues with the latest beta of domoticz base system. it works with the latest stable.JelteV wrote: ↑Sunday 03 September 2017 21:35 Hi,
Anyway.
I have the latest BETA version of Domoticz running with GCM enabled. But i get an error.How can we fix this?Code: Select all
2017-09-03 21:34:28.085 Error: GCM: Could not send message, HTTP Error. 2017-09-03 21:34:28.086 Error: Notification sent (gcm) => Failed 2017-09-03 21:34:28.100 Active notification Subsystems: gcm (1/12)
Please wait until they fix Domoticz
- galadril
Re: Domoticz App
Re: Domoticz App
Bought the full version, works great!!!
Is it a suggestion to put the available camera's on the dashboard? That would be really nice!
Re: Domoticz App
@galadril
Downloaded it and bought the full version.
Any news about geofencing?
Good job.
Good job.
Re: Domoticz App
@galadrill good job!
Bought full version and review the app with 5stars!
You have in the program to release beta again?
- Domoticz version: 4.10538
Re: Domoticz App
Nice job. Also bought the full version and looking forward to geofencing
- felix63
- Domoticz version: 2020.1
Re: Domoticz App
I had the same problem which I 'solved' by first using the demo settings and then changing them from the settings menu. Good work-around but not a real solution to this bug.
Cheers,
Lex
- galadril
Re: Domoticz App
No, only that's on my extensive list
- galadril
Re: Domoticz App
Thanks, appreciated!
Yes.. beta channel is still being updated..
Re: Domoticz App
Were is the full version? Do I need to download the app store version or can I keep the testflight one?
Inviato dal mio iPhone utilizzando Tapatalk
- galadril
Re: Domoticz App
you could stay on beta if you like..marcotrumpet wrote: ↑Monday 04 September 2017 16:59 Were is the full version? Do I need to download the app store version or can I keep the testflight one?
- galadril
Re: Domoticz App
v1.01 is available in the app store.. with the fix for people with a barometer!
Re: Domoticz App
Hi Galadril,Bandbox wrote: ↑Sunday 03 September 2017 11:52Hi Galadril,galadril wrote: ↑Saturday 02 September 2017 19:56Can you pm me a viewer account with your remote settings so i can debug?Bandbox wrote: ↑Saturday 02 September 2017 19:55 All,
Plz your guidance.
Thx Anton
Thx Anton
Is there a way I can sent you the the requested info, Still not able to sent you a pm.
Thx Anton
Re: Domoticz App
Updated and it works... Also fixed the 'Weather' tab being blank which I supposed makes sense if it was the barometer device causing the issues!
All looking good, just purchased the premium version.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
- G3rard
- Target OS: -
- Domoticz version: No
Domoticz App
I can confirm this is working now with a barometer device. All devices are shown now, including the ones on the Weather tab.galadril wrote:v1.01 is available in the app store.. with the fix for people with a barometer!
When checking Logs, User variables and Events however I get an error, see output below.
The same error is shown when pressing the home button for the plans.
JSON Call: http://192.168.1.157:8084/json.htm?type=command¶m=getlog
The CancellationTokenSource has been disposed.
Kan geen logs ophalen
JSON Call: http://192.168.1.157:8084/json.htm?type=command¶m=getuservariables
JSON Call: http://192.168.1.157:8084/json.htm?type=events¶m=list
JSON Call: http://192.168.1.157:8084/json.htm?type=plans
Object reference not set to an instance of an object
Not using Domoticz anymore
