The weird thing about the the startup is that i seem to miss the log entry PluginSystem: Started, Python version '3.4.2
Hardware Monitor: Started
2017-05-14 21:24:33.498 ToonThermostat: Worker started...
2017-05-14 21:24:33.498 Wunderground: Worker started...
2017-05-14 21:24:33.499 DarkSky: Started...
2017-05-14 21:24:33.500 Pinger: Started
2017-05-14 21:24:33.501 Philips Hue: Worker started...
2017-05-14 21:24:33.501 XiaomiGateway: will listen on 9898 for hardware id 36
2017-05-14 21:24:33.512 XiaomiGateway: Worker started...
2017-05-14 21:24:33.513 EventSystem: reset all events...
2017-05-14 21:24:33.520 EventSystem: reset all device statuses...
2017-05-14 21:24:33.540 XiaomiGateway: Could not detect local IP address: resolve: Host not found (authoritative)
2017-05-14 21:24:33.540 Error: XiaomiGateway: system
2017-05-14 21:24:33.541 XiaomiGateway: stopped
2017-05-14 21:24:33.552 EventSystem: Started
2017-05-14 21:24:33.700 RFLink: Using serial port: /dev/ttyACM0
2017-05-14 21:24:33.770 PluginSystem: Entering work loop.
2017-05-14 21:24:34.001 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-05-14 21:24:34.056 OpenZWave: Starting...
2017-05-14 21:24:34.056 OpenZWave: Version: 1.4-2501-g5af6780-dirty
2017-05-14 21:24:34.275 OpenZWave: Driver Ready
2017-05-14 21:24:34.289 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2017-05-14 21:24:34.289 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2017-05-14 21:24:34.290 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2017-05-14 21:24:34.290 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 25
2017-05-14 21:24:34.290 OpenZWave: Value_Added: Unhandled Label: Seismic Intensity, Unit:
2017-05-14 21:24:34.291 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-05-14 21:24:34.291 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-05-14 21:24:34.292 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-05-14 21:24:34.292 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Burglar, Instance: 1
2017-05-14 21:24:34.293 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2017-05-14 21:24:34.293 OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR ALARM, Label: General, Instance: 1
2017-05-14 21:24:34.295 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-14 21:24:34.295 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
2017-05-14 21:24:34.296 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: METER, Label: Energy, Instance: 1
2017-05-14 21:24:34.297 OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: METER, Label: Power, Instance: 1
2017-05-14 21:24:34.299 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-14 21:24:34.299 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-05-14 21:24:34.299 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-05-14 21:24:34.299 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-05-14 21:24:34.300 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-14 21:24:34.300 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
2017-05-14 21:24:34.300 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
2017-05-14 21:24:34.300 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 1
2017-05-14 21:24:34.301 OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 1
2017-05-14 21:24:34.405 Incoming connection from: 192.168.1.27
2017-05-14 21:24:34.617 RFLink: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
2017-05-14 21:24:34.617 RFLink: Controller Initialized!...
2017-05-14 21:24:34.692 RFLink: 20;01;MiLight=ON;
2017-05-14 21:24:34.693 RFLink: 20;02;VER=1.1;REV=46;BUILD=0c;
2017-05-14 21:24:34.693 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-05-14 21:24:34.815 (IP Checker) Initialized version 1.0.0, author 'ycahome'
