Timer (x) minutes before sunset
DespyNL
Domoticz version: v4.9701
Post by DespyNL »
Is it possible to trigger a script (x) minutes before sunset?
I have some lights which I switch on at sunset. Sometimes it's already dusk so I would like to switch them a little earlier.
I could create a dummy switch with a timer, but I was wondering if this can also be done with Dzvents timer trigger.
Milifax
Domoticz version: 2024.4
Re: Timer (x) minutes before sunset
Post by Milifax »
I use this in my Dzvents-script.
Basically LUA what Dzvents basically is as I understood.
-- Only let the lights switch on if they are within a set time before sunset
        local HoursNow = tonumber(os.date("%H"));
        local MinutesNow = tonumber(os.date("%M"));
        local TimeInMinutesNow = MinutesNow + HoursNow * 60
        local SetTimeBeforeSunset  = timeofday['SunsetInMinutes']-150 -- 2 1/2 hour before sunset (150 minutes)
        if ( ......blablabla.... and  (TimeInMinutesNow > SetTimeBeforeSunset) and .....blabla.........) then
Hope this helps
bimse
Domoticz version: Model 3
Post by bimse »
my method.
active = true,
timer = { '65 minutes before sunset'}
execute = function(domoticz)
if domoticz.time.matchesRule('65 minutes before sunset') then
domoticz.devices('Light Switch').switchOn().forMin(320)
Translated with google
snuiter
Post by snuiter »
Please see the wiki page on DzVents as it offers many options to simplify you LUA scripts. For e.g. for the timers functions where with LUA you had to do calculations.
http://www.domoticz.com/wiki/DzVents:_n ... er_options
Just add one of the many timer options in the timer section : 'xx minutes before sunset', 'xx minutes after sunset', 'xx minutes before sunrise', 'xx minutes after sunrise'
My script for sunset
	active = true,
        timer = {
            '40 minutes before sunset'
	        domoticz.setScene('woonkamer lampen','On')
	        domoticz.notify('','ACTION: sunset',domoticz.PRIORITY_LOW)
            domoticz.log('ACTION : Sunset', domoticz.LOG_INFO)
Toulon7559
Domoticz version: mixed
Post by Toulon7559 »
Simplest is to use the Timer linked to a Switch.
Go to Dashboard/ Switches, select the desired Switch, select Timers, and then you have plenty of choices, relative to fixed clocktime, relative to sunrise, relative to sunset, related to certain days, incl./excl. ambiguity, etc.
Last edited by Toulon7559 on Wednesday 30 August 2017 15:36, edited 1 time in total.
DespyNL
Post by DespyNL »
I've read the manual, but I totally missed the 'xx minutes before sunrise' part.
Thanks for all the help!
