The two scripts for each squeezebox player to get volume status/power etc.. One is for device change and one is time. Please see them below, is it possible to combine all 8 device changes into one LUA script? Many Thanks
if ((devicechanged['Bathroom Radio'] == 'On' or devicechanged['Bathroom Radio'] == 'Playing') and uservariables['BTH'] == 'Off') then
commandArray[#commandArray+1]={['Variable:LTV1'] = 'On'}
--commandArray[#commandArray+1]={['Lounge Touch']='Set Volume 30'}
--os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=265&switchcmd=Set%20Level&level=30" &')
elseif (devicechanged['Bathroom Radio'] == 'Off' or devicechanged['Bathroom Radio'] == 'Stopped' or devicechanged['Bathroom Radio'] == 'Disconnected') then
if otherdevices['Bathroom Radio V'] ~= 'Off' then
commandArray[#commandArray+1]={['Bathroom Radio V'] = 'Off'}
commandArray[#commandArray+1]={['Variable:BTH'] = 'Off'}
if devicechanged['Bathroom Radio V'] ~= 'Off' and devicechanged['Bathroom Radio V'] ~= nil then
if tonumber(otherdevices_svalues['Bathroom Radio V']) > 0 then
volume = otherdevices_svalues['Bathroom Radio V']
commandArray['Bathroom Radio']='Set Volume '..volume
return commandArrayCode: Select all
if otherdevices['Squeezeboxes'] == 'On' and (otherdevices['Bathroom Radio'] ~= 'Disconnected') then
json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()
file = assert(io.popen('curl \'http://192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["aa:aa:f8:02:4e:bd",["status","-","1",""]]}\''))
raw = file:read('*all')
file:close()
deviceinfo = json:decode(raw)
powerstatus = deviceinfo.result.power
playervolume = deviceinfo.result["mixer volume"] + 1
switchvolume = otherdevices_svalues['Bathroom Radio V']
difference = math.abs(switchvolume - playervolume)
if difference > 1 and tonumber(powerstatus) == 1 then
os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=361&switchcmd=Set%20Level&level='..playervolume..'" &')
if tonumber(powerstatus) == 1 and otherdevices['Bathroom Radio V'] == 'Off' then
