If I would like to use a module in my dzVents script using "require" I can not just create a file mymodule.lua and place it in the dzVents script folder because dzVents will try to load all lua files assuming they are ordinary dzVents scripts.
I can solve that by choosing to place my module in a different folder and change the package.path etc etc but it can be quite difficult if I want my script to run on all platforms.
Would it be possible to reserve a name space (E.g. my_*) for lua scripts in the dzVents script folder that will be excluded from being loaded by dzVents?
Cheers!
Using modules in dzVents
dannybloe
Re: Using modules in dzVents
Better have another designated folder as a sibling to dzvents/scripts maybe.
dannybloe
Doler
I just use ...dzVents/scripts/modules for this.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
dannybloe
I'll add the modules subfolder then to the package paths.
Doler
Great!
roblom
Maybe a stupid question, but what is a module?
