Everspring ST814 Temperature and Humidity Sensor
corederoma82
Post by corederoma82 »
I have just a little bit of confusion in my head. :D
I have domticz running on Windows system, I would like to know if is possible to do this configuration:
I would install the Everspring ST814 Temperature and Humidity Sensor.....but, to read this sensor, it's possibile install the Vera Edge with LAN (http://getvera.com/controllers/veraedge/) and then read it in Domoticz?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
heggink
Domoticz version: 12451
Re: Everspring ST814 Temperature and Humidity Sensor
Post by heggink »
Is that because you have no zwave on domoticz? I use the st814 with domoticz just fine.
DASHTICZ 🙃
P1 meter & solar panel
corederoma82
What you means? Can you said me how you install the st814 ? I have no zwave receivers.
