I have a Qubino ZMNHOD1 Flush Shutter DC+ in my bedroom controlling a blinder.
If I have my door closed Domoticz fails to communicate with it at it's current location.
I'm thinking extending the antenna with a piece of cable, any suggestions on that ?
TIA
Daniel
Extend range of Qubino ZMNHOD1 Flush Shutter DC+
- Varazir
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
TDK20
- Domoticz version: 3.8367
Re: Extend range of Qubino ZMNHOD1 Flush Shutter DC+
May I suggest a repeater instead? Another way you could try is place an metal reflector beside your RasPi (can use a cut open aluminum can).
YcKe
Hi Varazir,
As suggested by TDK20, I would suggest using an extra node to extend the range.
I would suggest installing a Fibaro Wall plug which you could also use to turn on/off any wall plug devices.
I have this device installed myself and it increases the z-wave mesh coverage significantly.
Greetz YcKe
Greetz YcKe
- Varazir
@ycke and @TDK20
Thanks, could place a wall plug just by the door.
//Daniel
//Daniel
