Multi value custom sensor
- Domoticz version: 3.5877
I love domoticz and applaud the develpment team.
I know we keep asking for more and more ...
Would it be possible to create a custom sensor with more than one value like the thermometer/hygrometer combo?
This way we can create bandwith sensors with up- and download speeds in one graph or other combination sensors like lightning with number of discharges and distance in one graph.
The sensor could then be filled by scripts using json or mqtt.
Regards,
Justme
Regards,
Justme
Raspberry Pi B+ Domoticz 2.2357
Re: Multi value custom sensor
+1, I'd combine my internet usage upload and download custom sensors into a single custom sensor.
viewtopic.php?f=63&p=117531#p117531
Would really appreciate this feature.
- Domoticz version: v4.11307
Same for me !ben53252642 wrote:+1, I'd combine my internet usage upload and download custom sensors into a single custom sensor.
And for other sensors too like my Mi Flora.
It would be very nice !
And btw dev make a really good work !
- Domoticz version: 3.8153
Same here. Although I'm using ISP's bandwidth page and node-js scrap-it module + mqtt to post data to Domoticz.
Thanks dev for such an awesome platform.
- Domoticz.png (33.19 KiB) Viewed 13194 times
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
+1 would really like that!
- Domoticz version: current
Couldn't groups kind of fullfill this idea?
I recently created a wireframe for a usability redesign.
https://www.domoticz.com/forum/viewtopi ... =8&t=16255
In it I still had devices as horizontal blocks. But I now think it would be way easier if anything on the dashboard can scale arbitrairily in height. A masonry javascript could then stack everything together optimally.
If a number of things are grouped, then the display of that group could show an interface that is is smart about what is inside that group.
- Only sensors: show sensor values in a list.
- 3 sensors and a switch: show sensor values and a toggle button.
- 4 buttons: show 1 toggle button.
- 3 buttons and one slider: show 1 toggle button and 1 slider.
etc
etc
@blauwebuis
I don't know if the groups from your proposal could do this. I for one would like to see the sensors details combined. So I can see multiple values in one graph like you can do with the temperature and see correlations.
But with the temperature, although you can do this, you need to "reprogram" the settings each time you request them.
So the request for multi value custom sensors is beyond what is shown on the dashboard.
+1
I really like this suggestion!
Ah I now see I totally misunderstood what you wanted
- Pepsi92
+1 ... custom sensors (CS) with double values / axis would be great
This would allow us to reduce the number of CS by merging similar values into one graph. By example :
- bandwidth (upload & download)
- counters (value & percentage)
- power (watt & VA)
- power (watt & VA)
Domoticz Beta 2023.2-15636
Raspberry Pi 4 - RaspiOS Lite 64 bits Bullseye 2023-10-10
RFXCOM RFXtrx433E - Ext/1011
AEON LABS Z-Wave Plus Z-Stick GEN5
USBTIC Teleinfo module
Even if this is not the solution sought in this thread, I think this would be as awesome feature for the dashboard page!blauwebuis wrote: - Only sensors: show sensor values in a list.
etc
+1 for Multi value custom sensor
+1
I already asked something similar in another post. Somewhere.
But in general the possibility to create graphs with flexible legenda and multiple values will be a godsend.
e.g. I have a fine-dust meter which outputs ppm for 2.5µ and 10µm particles...
I totally join the crowd to ask for such a feature.
Regarding the particule sensor, I am creating one as well that provide multiple values (PM, particule counts of various sizes) and feed Domoticz through a MQTT broker, but at the end I have so many different virtual devices that it make the analysis unreadable.
My sensor software is available here: https://github.com/ChrisP-Git/PartSense, and the hardware/3D files here: https://www.thingiverse.com/thing:2320020
+1
I would love to have such a type of multiple value sensor.
It would solve the problem of all clustered pages full of sensors.
Also it would make it easier to implement homebrew sensors with EspEasy or what so ever.
Best regards Bert
Synology DS1517+ - DSM 6.2
I would also love to have the option for multi value sensor.
I'm now measuring my floorheating water in and out temperature and calculate the delta T(temp difference) and would love to push these into 1 sensor and thus graph. Im now cluttering my Temperature tab with 5 lines of in, out and delta T values.
- Domoticz version: V3.6028
+1 I like to get a custom multi sensors device. I face the issue with a fridge that I want to get as "device" in one place. For example the door of fridge was recognized as switch, internal temp/hum found on temperature tab and power usage on utility tab....what a mess!
>>>> Google Home <<<<<
- Domoticz version: stable
+1
I use a DSM501 dust sensor sending PM10 and PM2.5 to domoticz.
It runs on a Wemos D1 mini with custom ESPeasy using plugin 114.
"I never make the same mistake twice. I make it like five or six times, you know, just to be sure."
+1
something like P1 Smart Meter device which can hold 6 values. But instead of:
it can hold customnumber1, customnumber2, text1, switch1 at the same time with configurable units?
typedef struct _tP1Power {
uint8_t len;
uint8_t type;
uint8_t subtype;
uint32_t powerusage1;
uint32_t powerusage2;
uint32_t powerdeliv1;
uint32_t powerdeliv2;
uint32_t usagecurrent;
uint32_t delivcurrent;
int32_t ID;
_tP1Power()
len = sizeof(_tP1Power) - 1;
type = pTypeP1Power;
subtype = sTypeP1Power;
ID = 1;
powerusage1 = 0;
powerusage2 = 0;
powerdeliv1 = 0;
powerdeliv2 = 0;
usagecurrent = 0;
delivcurrent = 0;
} P1Power;
