I have installed a new thermostat, SRT321 in my network. It was no problem to include it. If I change set point using the wheel on the thermostat, it updates the controller immediately, but it doesn't not work the other way around, if I try to change the set point on the controller. I have changed the wakeup time to 300s, and would expect the set point to be updated within 5min. Looks like this is a range issue (not sure why it is only an issue from controller to device and not vice versa?). Looking in the log: 2017-08-16 19:30:53.001 OpenZWave: Received timeout notification from HomeID: 3466478656, NodeID: 30 (0x1e)
Anyway I installed a Aeotec ZW080 Siren Gen5 (device 27) 1m away from the thermostat (Device 30) - this is communicating good with the controller (through other devices). I thought that the thermostat would route the signal through this device after a "heal network" - but it does not?
Am I doing something wrong?
