I am using my simple plugin for WeMo Switch for some time, now I am releasing in publicly. Feel free to test it and send me a comments etc. Plugin and Readme is available on GitHub:
https://github.com/milanvo/domoticz-plu ... emo-switch
Plugin - WeMo Switch
mivo
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
andi216
- Domoticz version: 3.7243
Re: Plugin - WeMo Switch
@mivo
Thanks for the plugin. It works very well.
(Rasp B + v3.8153 and Rasp V2 v3.8312).
In the future can change the plugin to add new Wemo devices (similar to Ping device)?
mivo
thank you for feedback. I thought about more addresses for WeMo switches, Python plugins has limited options for configuration parameters. Ping hardware has sub-page for setup - native device in C++ code. Do you have more WeMo for testing ? I have only one
. I will try to add option to specify more addresses in field, comma separated.
My toys:
r3wt3d
I tried this out and it seems to work, however I have error in my log
When I turn off I get this:
2017-11-13 14:45:47.025 Error: (xxxxxxx) Except updStatus: 0|1510551709|236|2059|357681|1209600|83|55680|1194829|473422122
When I turn on I get this:
2017-11-13 14:46:25.091 Error: (xxxxxxx) Except updStatus: 8|1510551947|236|2059|357681|1209600|48|0|1194829|473422122
Icon changes after onHeartbeat it seems.
2017-11-13 14:46:39.336 (zzzzzzzz) Updating device from 0:'0' to have values 1:'100'.
2017-11-13 14:46:39.347 (xxxxxxx) Updated to: 1
How can I fix it?
How can I fix it?
r3wt3d
Ok I fixed it...and I additionally added dirty support for WeMo insight switch.
It seems that WeMo is only sending extended status back when turning on/off the switch,
I turn on the relay on every heartbeat if it is already switched on to receive the energy data.
Normally it seems it feeds with upnp, but I have no clue how to grab it on python.
You could probably use this and create a script to update via API:
https://github.com/timonreinhard/wemo-client (check the test directory)
While researching I found this:
https://ouimeaux.readthedocs.io/en/latest/wemo.html
http://moderntoil.com/?p=839
I didn't look deeply inside but maybe I could have used this aswell:
https://github.com/mgsg/domoticz-sonos-plugin
anyway here is the code..
I'm pretty new to python and Domoticz so maybe there are some mistakes you guys can correct...
This script will add a "Insight" True/False switch to Hardware and if you change it to True and restart domoticz
it will create a counter device if not done already, and updates every heartbeat with the latest energy consumption.
Don't forget to enable it.
- Spoiler: show
#!/usr/bin/python3 # # Domoticz Python Plugin for WeMo Switch by Belkin # Added support for WeMo Insight switch - r3wt3d 2017/11/16 # Based on code from: # https://gist.github.com/pruppert/af7d38cb7b7ca75584ef # https://github.com/pdumoulin/blinky # # Author: mivo # """ <plugin key="wemo-switch" name="WeMo Switch (plugin)" author="mivo" version="0.1" wikilink="http://www.domoticz.com/wiki/plugins" externallink="https://github.com/milanvo/domoticz-plugins"> <params> <param field="Address" label="IP Address" width="200px" required="true"/> <param field="Port" label="Port" width="50px" required="true" default="49153"/> <param field="Mode1" label="Insight" width="50px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode6" label="Debug" width="75px"> <options> <option label="True" value="Debug"/> <option label="False" value="Normal" default="true"/> </options> </param> </params> </plugin> """ import Domoticz import urllib.request class wemoSwitch: ip = None ports = [49153, 49152, 49154, 49151, 49155] def __init__(self, switch_ip=None, switch_port=None): self.ip = switch_ip if switch_port: self.ports = [switch_port] def action(self, action): value = None if action == 'on': method, obj, value = ('Set', 'BinaryState', 1) elif action == 'off': method, obj, value = ('Set', 'BinaryState', 0) elif action == 'status': method, obj = ('Get', 'BinaryState') elif action == 'name': method, obj = ('Get', 'FriendlyName') elif action == 'signal': method, obj = ('Get', 'SignalStrength') return self._send(method, obj, value) def on(self): return self.action('on') def off(self): return self.action('off') def status(self): return self.action('status') def name(self): return self.action('name') def signal(self): return self.action('signal') def _get_header_xml(self, method, obj): method = method + obj return '"urn:Belkin:service:basicevent:1#%s"' % method def _get_body_xml(self, method, obj, value=0): method = method + obj return '<u:%s xmlns:u="urn:Belkin:service:basicevent:1"><%s>%s</%s></u:%s>' % (method, obj, value, obj, method) def _send(self, method, obj, value=None): body_xml = self._get_body_xml(method, obj, value) header_xml = self._get_header_xml(method, obj) for port in self.ports: result = self._try_send(self.ip, port, body_xml, header_xml, obj) if result is not None: self.ports = [port] return result raise Exception("_send TimeoutOnAllPorts") def _try_send(self, ip, port, body, header, data): try: request = urllib.request.Request('http://%s:%s/upnp/control/basicevent1' % (ip, port)) request.add_header('Content-type', 'text/xml; charset="utf-8"') request.add_header('SOAPACTION', header) request_body = '<?xml version="1.0" encoding="utf-8"?>' request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' request_body += '<s:Body>%s</s:Body></s:Envelope>' % body request.data = request_body.encode() result = urllib.request.urlopen(request, timeout=3) return self._extract(result.read().decode(), data) except Exception as e: # except: # raise print(str(e)) return None def _get_request_data(self, method, obj, value=None): body_xml = self._get_body_xml(method, obj, value) header_xml = self._get_header_xml(method, obj) headers = dict() url = '/upnp/control/basicevent1' headers['Content-type'] = 'text/xml; charset="utf-8"' headers['SOAPACTION'] = header_xml body = '<?xml version="1.0" encoding="utf-8"?>' \ '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' body += '<s:Body>%s</s:Body></s:Envelope>' % body_xml headers['Content-Length'] = "%d"%(len(body)) return dict(url=url, headers=headers, body=body) def _extract(self, XML, tagName): #print('XML:', XML) #print('tagName:', tagName) startTag = '<%s>' % (tagName) endTag = '</%s>' % (tagName) startPos = XML.find(startTag) endPos = XML.find(endTag, startPos+1) #print('start end:', startPos, endPos) if ((startPos == -1) or (endPos == -1)): print("'"+tagName+"' not found in supplied XML") raise Exception("_extract" + "'"+tagName+"' not found in supplied XML") return False #if ((startPos == -1) or (endPos == -1)): Domoticz.Error("'"+tagName+"' not found in supplied XML") #print('vystup:', XML[startPos+len(startTag):endPos]) return XML[startPos+len(startTag):endPos] global switch switch = wemoSwitch() def onStart(): global switch if Parameters["Mode6"] == "Debug": Domoticz.Debugging(1) if (len(Devices) == 0): Domoticz.Device(Name="Switch 1", Unit=1, TypeName="Switch").Create() Domoticz.Log("Device created.") if (2 not in Devices and Parameters["Mode1"] == "YES"): Domoticz.Device(Name="Power", Unit=2, TypeName="kWh").Create() Domoticz.Log("kWh Device created.") Domoticz.Heartbeat(30) switch.ip = Parameters["Address"] switch.port = Parameters["Port"] try: status = switch.status() except Exception as e: Domoticz.Error('Except onStart: ' + str(e)) return updStatus(status) DumpConfigToLog() def onStop(): Domoticz.Log("Plugin is stopping.") def onCommand(Unit, Command, Level, Hue): global switch try: if (Command.upper() == 'ON'): status = switch.on() else: status = switch.off() except Exception as e: Domoticz.Error('Except onCommand: ' + str(e)) return updStatus(status) def onHeartbeat(): global switch try: status = switch.status() except Exception as e: Domoticz.Error('Except onHeartbeat: ' + str(e)) return Domoticz.Debug(str(status)) if int(status[0:1]) == 1 and Parameters["Mode1"] == "YES": power = str(switch.on()).split('|') kwh = str(int(power[7])/1000) Domoticz.Debug(kwh) Devices[2].Update(0,kwh) if int(status[0:1]) == 0 and Parameters["Mode1"] == "YES": Devices[2].Update(0,"0.000") updStatus(status) def updStatus(status): if not status: Domoticz.Error('False updStatus: ' + str(status)) return try: istatus = int(status[0:1]) except ValueError: Domoticz.Error('Except updStatus: ' + str(status)) return Domoticz.Debug('Status: ' + str(status) + ' iStatus: ' + str(istatus)) if istatus == 1: if (1 in Devices): if Devices[1].nValue == 0: #if Devices[1].sValue == "Off": Devices[1].Update(1,"On") Domoticz.Debug('Updated to: ' + str(istatus)) elif istatus == 0: if (1 in Devices): if Devices[1].nValue == 1: #if Devices[1].sValue == "On": Devices[1].Update(0,"Off") Domoticz.Debug('Updated to: ' + str(istatus)) elif istatus == 8: if (1 in Devices): if Devices[1].nValue == 0: Devices[1].Update(1,"On") Domoticz.Debug('Updated to: ' + str(istatus)) #DumpConfigToLog() # Generic helper functions def DumpConfigToLog(): for x in Parameters: if Parameters[x] != "": Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'") Domoticz.Debug("Device count: " + str(len(Devices))) for x in Devices: Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x])) Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'") Domoticz.Debug("Device Name: '" + Devices[x].Name + "'") Domoticz.Debug("Device nValue: " + str(Devices[x].nValue)) Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'") Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel)) return def main(): import argparse parser = argparse.ArgumentParser(description='WeMo Switch control module for Python') parser.add_argument('action', choices=['on', 'off', 'status', 'name', 'signal'], help='Action') parser.add_argument('ip', help='IP address') parser.add_argument('port', nargs='?', default='49153', help='Port') args = parser.parse_args() IP=args.ip PORT=args.port switch = wemoSwitch(IP, PORT) if args.action: print(switch.action(args.action)) if __name__ == '__main__': main()
huey
Hi, I have taken the liberty of using your and mivo's code and adjusted it a bit for the Wemo Insight. Still working on it to see if i can get the standby status and info in a bit better...
I will include the code, maybe anyone has some additional ideas and pointers.
- Spoiler: show
#!/usr/bin/python3 # # Domoticz Python Plugin for WeMo Insight by Belkin # Modifications for WeMo Insight switch and rename to wemo-insight - huey 2018/04/16 # Added support for WeMo Insight switch - r3wt3d 2017/11/16 # Based on code from: # https://gist.github.com/pruppert/af7d38cb7b7ca75584ef # https://github.com/pdumoulin/blinky # # Author: mivo # """ <plugin key="wemo-insight" name="WeMo Insight (plugin)" author="huey, with thx to mivo and r3wt3d" version="0.1" wikilink="http://www.domoticz.com/wiki/plugins" > <params> <param field="Address" label="IP Address" width="200px" required="true"/> <param field="Port" label="Port" width="50px" required="true" default="49153"/> <param field="Mode1" label="Power" width="75px"> <options> <option label="True" value="YES" default="true"/> <option label="False" value="NO"/> </options> </param> <param field="Mode2" label="OnFor Usage" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode3" label="OnToday Usage" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode4" label="Summary" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode6" label="Debug" width="75px"> <options> <option label="True" value="Debug"/> <option label="False" value="Normal" default="true"/> <option label="Logging" value="File"/> </options> </param> </params> </plugin> """ import Domoticz import urllib.request import datetime class wemoInsight: ip = None ports = [49153, 49152, 49154, 49151, 49155] def __init__(self, insight_ip=None, insight_port=None): self.ip = insight_ip if insight_port: self.ports = [insight_port] def action(self, action): value = None if action == 'on': event, method, obj, value = ('basicevent', 'Set', 'BinaryState', 1) return self._send(event, method, obj, value) elif action == 'off': event, method, obj, value = ('basicevent', 'Set', 'BinaryState', 0) return self._send(event, method, obj, value) elif action == 'status': event, method, obj = ('basicevent', 'Get', 'BinaryState') return self._send(event, method, obj, value) elif action == 'name': event, method, obj = ('basicevent', 'Get', 'FriendlyName') return self._send(event, method, obj, value) elif action == 'signal': event, method, obj = ('basicevent', 'Get', 'SignalStrength') return self._send(event, method, obj, value) elif action == 'params': event, method, obj = ('insight', 'Get', 'InsightParams') return self._send(event, method, obj, value) elif action == 'autopowerthreshold': event, method, obj = ('insight', 'SetAuto', 'PowerThreshold') return self._send(event, method, obj, value) elif action == 'setpowerthreshold': event, method, obj = ('insight', 'Set', 'PowerThreshold', value) return self._send(event, method, obj, value) elif action == 'resetpowerthreshold': event, method, obj = ('insight', 'Reset', 'PowerThreshold') return self._send(event, method, obj, value) def on(self): return self.action('on') def off(self): return self.action('off') def status(self): return self.action('status') def name(self): return self.action('name') def signal(self): return self.action('signal') def params(self): return self.action('params') def autopowerthreshold(self): return self.action('autopowerthreshold') def setpowerthreshold(self): return self.action('setpowerthreshold') def resetpowerthreshold(self): return self.action('resetpowerthreshold') def _get_header_xml(self, event, method, obj): method = method + obj return '"urn:Belkin:service:%s:1#%s"' % (event, method) def _get_body_xml(self, event, method, obj, value=0): method = method + obj return '<u:%s xmlns:u="urn:Belkin:service:%s:1"><%s>%s</%s></u:%s>' % (method, event, obj, value, obj, method) def _send(self, event, method, obj, value=None): body_xml = self._get_body_xml(event, method, obj, value) header_xml = self._get_header_xml(event, method, obj) for port in self.ports: result = self._try_send(self.ip, port, body_xml, header_xml, obj, event) if result is not None: self.ports = [port] return result raise Exception("_send TimeoutOnAllPorts") def _try_send(self, ip, port, body, header, data, event): try: request = urllib.request.Request('http://%s:%s/upnp/control/%s1' % (ip, port, event)) request.add_header('Content-type', 'text/xml; charset="utf-8"') request.add_header('SOAPACTION', header) request_body = '<?xml version="1.0" encoding="utf-8"?>' request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' request_body += '<s:Body>%s</s:Body></s:Envelope>' % body request.data = request_body.encode() result = urllib.request.urlopen(request, timeout=3) return self._extract(result.read().decode(), data) except Exception as e: # except: # raise print(str(e)) return None #huey: not sure what this is for, seems unused to me. # def _get_request_data(self, event, method, obj, value=None): # body_xml = self._get_body_xml(event, method, obj, value) # header_xml = self._get_header_xml(event, method, obj) # headers = dict() # # url = '/upnp/control/%s1' % event # headers['Content-type'] = 'text/xml; charset="utf-8"' # headers['SOAPACTION'] = header_xml # # body = '<?xml version="1.0" encoding="utf-8"?>' \ # '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' # body += '<s:Body>%s</s:Body></s:Envelope>' % body_xml # # headers['Content-Length'] = "%d"%(len(body)) # # return dict(url=url, headers=headers, body=body) def _extract(self, XML, tagName): #Domoticz.Debug('XML: ' + XML) #Domoticz.Debug('tagName: ' + tagName) startTag = '<%s>' % (tagName) endTag = '</%s>' % (tagName) startPos = XML.find(startTag) endPos = XML.find(endTag, startPos+1) #Domoticz.Debug('start end: ' + str(startPos) + ' ' + str(endPos)) if ((startPos == -1) or (endPos == -1)): raise Exception("_extract" + "'"+tagName+"' not found in supplied XML") return False #if ((startPos == -1) or (endPos == -1)): Domoticz.Error("'"+tagName+"' not found in supplied XML") #print('vystup:', XML[startPos+len(startTag):endPos]) return XML[startPos+len(startTag):endPos] global insight insight = wemoInsight() def onStart(): global insight Domoticz.Log("* Plugin is starting *") if Parameters["Mode6"] == "Debug": Domoticz.Debugging(1) DumpConfigToLog() #huey: can not get external imports to work... #Domoticz.Log("Debugger started, use 'telnet 0.0.0.0 4444' to connect") #import rpdb #rpdb.set_trace() # if 'WeMoInsightLogo' not in Images: Domoticz.Image('wemo-insight.zip').Create() if (len(Devices) == 0): Domoticz.Device(Name="Switch", Unit=1, TypeName="Switch", Used=1).Create() Domoticz.Log("Switch Device created.") if (2 not in Devices and Parameters["Mode1"] == "YES"): Domoticz.Device(Name="Power", Unit=2, TypeName="kWh", Used=1).Create() Domoticz.Log("kWh Device created.") if (3 not in Devices and Parameters["Mode2"] == "YES"): Domoticz.Device(Name="OnFor", Unit=3, TypeName="Custom", Options = { "Custom" : "1;seconds"}, Used=0).Create() UpdateImage(3, 'WeMoInsightLogo') Domoticz.Log("OnFor Custom Device created.") if (4 not in Devices and Parameters["Mode3"] == "YES"): Domoticz.Device(Name="OnTodayFor", Unit=4, TypeName="Custom", Options = { "Custom" : "1;seconds"}, Used=0).Create() UpdateImage(4, 'WeMoInsightLogo') Domoticz.Log("OnToday Custom Device created.") if (5 not in Devices and Parameters["Mode4"] == "YES"): Domoticz.Device(Name="Summary", Unit=5, TypeName="Text", Used=0).Create() Domoticz.Log("Summary Text Device created.") # if 3 in Devices: # UpdateImage(3, 'WeMoInsightLogo') # if 4 in Devices: # UpdateImage(4, 'WeMoInsightLogo') # Domoticz.Heartbeat(30) Domoticz.Heartbeat(60) insight.ip = Parameters["Address"] insight.port = Parameters["Port"] def onStop(): Domoticz.Log("* Plugin is stopping *") def onCommand(Unit, Command, Level, Hue): global insight Domoticz.Debug("onCommand called") try: if (Command.upper() == 'ON'): status = insight.on() else: status = insight.off() except Exception as e: Domoticz.Error('Except onCommand: ' + str(e)) return updStatus(status) def onHeartbeat(): global insight Domoticz.Debug("* onHeartBeat called *") try: params = insight.params() except Exception as e: Domoticz.Error('Except onHeartbeat: ' + str(e)) return Domoticz.Debug('DebugParams: ' + str(params)) if params is None: Domoticz.Log('ERROR Params is undefined') else: state = int(params[0:1]) Domoticz.Debug('DebugState : ' + str(state)) power = str(insight.params()).split('|') #if state >= 1: updStatus(params) if Parameters["Mode2"] == "YES": Domoticz.Debug("* Device 3 update called *") onfor = int(power[2]) Domoticz.Debug('DebugOnFor: ' + str(onfor)) Devices[3].Update(0,str(onfor)) if Parameters["Mode3"] == "YES": Domoticz.Debug("* Device 4 update called *") ontoday = int(power[3]) Domoticz.Debug('DebugOnToday: ' + str(ontoday)) Devices[4].Update(0,str(ontoday)) if Parameters["Mode4"] == "YES": Domoticz.Debug("* Device 5 update called *") lastchange = datetime.datetime.fromtimestamp(int(power[1])) Domoticz.Debug('DebugLastChange: ' + str(lastchange)) onfortext = datetime.timedelta(seconds=int(power[2])) Domoticz.Debug('DebugOnForText: ' + str(onfortext)) ontodaytext = datetime.timedelta(seconds=int(power[3])) Domoticz.Debug('DebugOnTodayText: ' + str(ontodaytext)) ontotal = int(power[4]) Domoticz.Debug('DebugOnTotal: ' + str(ontotal)) ontotaltext = datetime.timedelta(seconds=int(power[4])) Domoticz.Debug('DebugOnTotalText: ' + str(ontotaltext)) totalmw = int(float(power[9]))/1000 Domoticz.Debug('DebugTotalkWh: ' + str(totalmw)) threshold = int(power[10])/1000 Domoticz.Debug('DebugThreshold: ' + str(threshold)) Devices[5].Update(0,"On for: "+ str(onfortext) + "<br>" + "On today: " + str(ontodaytext) + "<br>" + "On total: " + str(ontotaltext) + "<br>" + "Total kWh: " + str(totalmw) + "<br>" + "Standby threshold: " + str(threshold) + "<br>" + "Last change: " + str(lastchange)) def updStatus(status): Domoticz.Debug("* updStatus called *") if not status: Domoticz.Error('False updStatus: ' + str(status)) return try: istate = int(status[0:1]) except ValueError: Domoticz.Error('Except updStatus: ' + str(status)) return Domoticz.Debug('DebugStatus: ' + str(status) + ' iState: ' + str(istate)) Domoticz.Debug("* Device 1 update called *") if istate == 1: if (1 in Devices): if Devices[1].nValue == 0: #if Devices[1].sValue == "Off": Devices[1].Update(1,"On") Domoticz.Debug('Updated to: ' + str(istate)) elif istate == 0: if (1 in Devices): if Devices[1].nValue == 1: #if Devices[1].sValue == "On": Devices[1].Update(0,"Off") Domoticz.Debug('Updated to: ' + str(istate)) elif istate == 8: if (1 in Devices): if Devices[1].nValue == 0: Devices[1].Update(1,"On") Domoticz.Debug('Updated to: ' + str(istate)) if Parameters["Mode1"] == "YES": Domoticz.Debug("* Device 2 update called *") # power = str(insight.params()).split('|') power = status.split('|') if Parameters["Mode1"] == "YES": currentmw = int(power[7])/1000 Domoticz.Debug('DebugkWh: ' + str(currentmw)) todaymw = int(power[8])/1000 Domoticz.Debug('DebugtoDay: ' + str(todaymw)) Devices[2].Update(0,str(currentmw) + "; " + str(todaymw)) # Synchronise images to match parameter in hardware page #def UpdateImage(Unit, Logo): # if Unit in Devices and Logo in Images: # if Devices[Unit].Image != Images[Logo].ID: # Domoticz.Log("Device Image update: 'WeMoInsight', Currently " + str(Devices[Unit].Image) + ", should be " + str(Images[Logo].ID)) # Devices[Unit].Update(nValue=Devices[Unit].nValue, sValue=str(Devices[Unit].sValue), Image=Images[Logo].ID) # return # Generic helper functions def LogMessage(Message): if Parameters["Mode6"] == "File": f = open(Parameters["HomeFolder"] + "plugin.log", "a") f.write(Message + "\r\n") f.close() Domoticz.Debug(Message) def DumpConfigToLog(): for x in Parameters: if Parameters[x] != "": LogMessage( "'" + x + "':'" + str(Parameters[x]) + "'") LogMessage("Device count: " + str(len(Devices))) for x in Devices: LogMessage("Device: " + str(x) + " - " + str(Devices[x])) LogMessage("Internal ID: '" + str(Devices[x].ID) + "'") LogMessage("External ID: '" + str(Devices[x].DeviceID) + "'") LogMessage("Device Name: '" + Devices[x].Name + "'") LogMessage("Device nValue: " + str(Devices[x].nValue)) LogMessage("Device sValue: '" + Devices[x].sValue + "'") LogMessage("Device LastLevel: " + str(Devices[x].LastLevel)) return def main(): import argparse parser = argparse.ArgumentParser(description='WeMo Insight control module for Python') parser.add_argument('action', choices=['on', 'off', 'status', 'name', 'signal', 'params', 'autopowerthreshold', 'setpowerthreshold', 'resetpowerthreshold'], help='Action') parser.add_argument('ip', help='IP address') parser.add_argument('port', nargs='?', default='49153', help='Port') args = parser.parse_args() IP=args.ip PORT=args.port insight = wemoInsight(IP, PORT) if args.action: print(insight.action(args.action)) if __name__ == '__main__': main()
huey
Latest and probably last version and with some icons.
- Spoiler: show
#!/usr/bin/python3 # # Domoticz Python Plugin for WeMo Insight by Belkin # Modifications for WeMo Insight switch and rename to wemo-insight - huey 2018/04/16 # Added support for WeMo Insight switch - r3wt3d 2017/11/16 # Based on code from: # https://gist.github.com/pruppert/af7d38cb7b7ca75584ef # https://github.com/pdumoulin/blinky # # Author: mivo # """ <plugin key="wemo-insight" name="WeMo Insight (plugin)" author="huey, with thx to mivo and r3wt3d" version="0.1" wikilink="http://www.domoticz.com/wiki/plugins" > <description> <h2>Belkin WeMo Insight plugin</h2><br/> <h3>Devices</h3> <ul style="list-style-type:square"> <li>Comes default with on/off switch and power</li> <li>Optional additional selector switch for more convenient logging of standby status</li> <li>Optional additional devices to log duration of last ontime and total for day in seconds</li> <li>Optional additional device with summary details text</li> <li>Optional additional device to reset standby threshold to default value of 8 or auto value</li> </ul> </description> <params> <param field="Address" label="IP Address" width="200px" required="true"/> <param field="Port" label="Port" width="50px" required="true" default="49153"/> <param field="Mode1" label="Standby status" width="75px"> <options> <option label="True" value="YES" default="true"/> <option label="False" value="NO"/> </options> </param> <param field="Mode2" label="On for seconds" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode3" label="Today seconds" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode4" label="Summary details" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode5" label="Standby reset" width="75px"> <options> <option label="True" value="YES"/> <option label="False" value="NO" default="true"/> </options> </param> <param field="Mode6" label="Debug" width="75px"> <options> <option label="True" value="Debug"/> <option label="False" value="Normal" default="true"/> </options> </param> </params> </plugin> """ ##import Domoticz try: import Domoticz except ImportError: def Log(s): print(s) def Debug(s): print(s) def Error(s): print(s) import sys import urllib.request import datetime class wemoInsight: ip = None ports = [49153, 49152, 49154, 49151, 49155] def __init__(self, insight_ip=None, insight_port=None): self.ip = insight_ip if insight_port: self.ports = [insight_port] def action(self, action): value = None if action == 'on': event, method, obj, value = ('basicevent', 'Set', 'BinaryState', 1) return self._send(event, method, obj, value) elif action == 'off': event, method, obj, value = ('basicevent', 'Set', 'BinaryState', 0) return self._send(event, method, obj, value) elif action == 'status': event, method, obj = ('basicevent', 'Get', 'BinaryState') return self._send(event, method, obj, value) elif action == 'name': event, method, obj = ('basicevent', 'Get', 'FriendlyName') return self._send(event, method, obj, value) elif action == 'signal': event, method, obj = ('basicevent', 'Get', 'SignalStrength') return self._send(event, method, obj, value) elif action == 'params': event, method, obj = ('insight', 'Get', 'InsightParams') return self._send(event, method, obj, value) elif action == 'autopowerthreshold': event, method, obj = ('insight', 'SetAuto', 'PowerThreshold') return self._send(event, method, obj, value) elif action == 'setpowerthreshold': event, method, obj, value = ('insight', 'Set', 'PowerThreshold', value) return self._send(event, method, obj, value) elif action == 'resetpowerthreshold': event, method, obj = ('insight', 'Reset', 'PowerThreshold') return self._send(event, method, obj, value) def on(self): return self.action('on') def off(self): return self.action('off') def status(self): return self.action('status') def name(self): return self.action('name') def signal(self): return self.action('signal') def params(self): return self.action('params') def autopowerthreshold(self): return self.action('autopowerthreshold') def setpowerthreshold(self): return self.action('setpowerthreshold') def resetpowerthreshold(self): return self.action('resetpowerthreshold') def _get_header_xml(self, event, method, obj): method = method + obj return '"urn:Belkin:service:%s:1#%s"' % (event, method) def _get_body_xml(self, event, method, obj, value=0): method = method + obj return '<u:%s xmlns:u="urn:Belkin:service:%s:1"><%s>%s</%s></u:%s>' % (method, event, obj, value, obj, method) def _send(self, event, method, obj, value=None): body_xml = self._get_body_xml(event, method, obj, value) header_xml = self._get_header_xml(event, method, obj) for port in self.ports: result = self._try_send(self.ip, port, body_xml, header_xml, obj, event) if result is not None: self.ports = [port] return result raise Exception("_send TimeoutOnAllPorts") def _try_send(self, ip, port, body, header, data, event): try: request = urllib.request.Request('http://%s:%s/upnp/control/%s1' % (ip, port, event)) request.add_header('Content-type', 'text/xml; charset="utf-8"') request.add_header('SOAPACTION', header) request_body = '<?xml version="1.0" encoding="utf-8"?>' request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' request_body += '<s:Body>%s</s:Body></s:Envelope>' % body request.data = request_body.encode() result = urllib.request.urlopen(request, timeout=3) return self._extract(result.read().decode(), data) except Exception as e: # except: # raise print(str(e)) return None #huey: not sure what this is for, seems unused to me. # def _get_request_data(self, event, method, obj, value=None): # body_xml = self._get_body_xml(event, method, obj, value) # header_xml = self._get_header_xml(event, method, obj) # headers = dict() # # url = '/upnp/control/%s1' % event # headers['Content-type'] = 'text/xml; charset="utf-8"' # headers['SOAPACTION'] = header_xml # # body = '<?xml version="1.0" encoding="utf-8"?>' \ # '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">' # body += '<s:Body>%s</s:Body></s:Envelope>' % body_xml # # headers['Content-Length'] = "%d"%(len(body)) # # return dict(url=url, headers=headers, body=body) def _extract(self, XML, tagName): #Domoticz.Debug('XML: ' + XML) #Domoticz.Debug('tagName: ' + tagName) startTag = '<%s>' % (tagName) endTag = '</%s>' % (tagName) startPos = XML.find(startTag) endPos = XML.find(endTag, startPos+1) #Domoticz.Debug('start end: ' + str(startPos) + ' ' + str(endPos)) if ((startPos == -1) or (endPos == -1)): raise Exception("_extract" + "'"+tagName+"' not found in supplied XML") return False #if ((startPos == -1) or (endPos == -1)): Domoticz.Error("'"+tagName+"' not found in supplied XML") #print('vystup:', XML[startPos+len(startTag):endPos]) return XML[startPos+len(startTag):endPos] global insight insight = wemoInsight() def onStart(): global insight Domoticz.Log("* Plugin is starting *") if Parameters["Mode6"] == "Debug": Domoticz.Debugging(1) Domoticz.Debug("sys.exec: " + str(sys.executable)) #sys.path.append('/usr/local/lib/python36/site-packages') Domoticz.Debug("sys.path: " + str(sys.path)) DumpConfigToLog() #huey: can not get external imports to work... #Domoticz.Log("Debugger started, use 'telnet 0.0.0.0 4444' to connect") #import rpdb #rpdb.set_trace() if 'WeMoInsight' not in Images: Domoticz.Debug("Create new images") Domoticz.Image('WeMoInsight.zip').Create() if (len(Devices) == 0): Domoticz.Device(Name="Switch", Unit=1, TypeName="Switch", Used=1).Create() Domoticz.Log("Switch Device created.") Domoticz.Device(Name="Power", Unit=2, TypeName="kWh", Used=1).Create() Domoticz.Log("kWh Device created.") if (3 not in Devices and Parameters["Mode2"] == "YES"): Domoticz.Device(Name="OnFor", Unit=3, TypeName="Custom", Options = { "Custom" : "1;s"}, Used=0).Create() Domoticz.Log("OnFor Custom Device created.") if (4 not in Devices and Parameters["Mode3"] == "YES"): Domoticz.Device(Name="OnTodayFor", Unit=4, TypeName="Custom", Options = { "Custom" : "1;s"}, Used=0).Create() Domoticz.Log("OnToday Custom Device created.") if (5 not in Devices and Parameters["Mode4"] == "YES"): Domoticz.Device(Name="Summary", Unit=5, TypeName="Text", Used=0).Create() Domoticz.Log("Summary Text Device created.") if (6 not in Devices and Parameters["Mode1"] == "YES"): OptionsStatus = {"LevelActions": "||", "LevelNames": "Off|On|Standby", "LevelOffHidden": "false", "SelectorStyle": "0"} Domoticz.Device(Name="Status", Unit=6, TypeName="Selector Switch", Switchtype=18, Image=12, Options=OptionsStatus, Used=0).Create() Domoticz.Log("Switch Status Device created.") if (7 not in Devices and Parameters["Mode5"] == "YES"): OptionsStandby = {"LevelActions": "||", "LevelNames": "Off|Default|Auto", "LevelOffHidden": "true", "SelectorStyle": "0"} Domoticz.Device(Name="Standby threshold", Unit=7, TypeName="Selector Switch", Switchtype=18, Image=12, Options=OptionsStandby, Used=0).Create() Domoticz.Log("Standby Reset Device created.") if 1 in Devices: UpdateImage(1, 'WeMoInsight') if 3 in Devices: UpdateImage(3, 'WeMoInsight') if 4 in Devices: UpdateImage(4, 'WeMoInsight') # if 5 in Devices: # UpdateImage(5, 'WeMoInsight') if 6 in Devices: UpdateImage(6, 'WeMoInsight') if 7 in Devices: UpdateImage(7, 'WeMoInsight') # Domoticz.Heartbeat(30) Domoticz.Heartbeat(60) insight.ip = Parameters["Address"] insight.port = Parameters["Port"] def onStop(): Domoticz.Log("* Plugin is stopping *") def onCommand(Unit, Command, Level, Hue): global insight Domoticz.Debug("onCommand called, unit: " + str(Unit) + " command: " + str(Command) + " level: " + str(Level) + " hue: " + str(Hue)) try: if (Command.upper() == 'ON') or (Unit == 6 and Command.upper() == 'SET LEVEL' and Level >= 10): status = insight.on() updStatus(status) elif (Unit == 7 and Command.upper() == 'SET LEVEL' and Level == 10): status = insight.resetpowerthreshold() Devices[7].Update(1,"10") Domoticz.Debug("Standby: 'Default (8)'") elif (Unit == 7 and Command.upper() == 'SET LEVEL' and Level == 20): status = insight.autopowerthreshold() Devices[7].Update(1,"20") Domoticz.Debug("Standby: 'Auto'") else: status = insight.off() updStatus(status) except Exception as e: Domoticz.Error('Except onCommand: ' + str(e)) return def onHeartbeat(): global insight Domoticz.Debug("* onHeartBeat called *") try: params = insight.params() except Exception as e: Domoticz.Error('Except onHeartbeat: ' + str(e)) return Domoticz.Debug('DebugParams: ' + str(params)) if params is None: Domoticz.Log('ERROR Params is undefined') else: state = int(params[0:1]) Domoticz.Debug('DebugState : ' + str(state)) power = str(insight.params()).split('|') #if state >= 1: updStatus(params) if Parameters["Mode2"] == "YES": Domoticz.Debug("* Device 3 update called *") onfor = int(power[2]) Domoticz.Debug('DebugOnFor: ' + str(onfor)) Devices[3].Update(0,str(onfor)) if Parameters["Mode3"] == "YES": Domoticz.Debug("* Device 4 update called *") ontoday = int(power[3]) Domoticz.Debug('DebugOnToday: ' + str(ontoday)) Devices[4].Update(0,str(ontoday)) if Parameters["Mode4"] == "YES": Domoticz.Debug("* Device 5 update called *") lastchange = datetime.datetime.fromtimestamp(int(power[1])) Domoticz.Debug('DebugLastChange: ' + str(lastchange)) onfortext = datetime.timedelta(seconds=int(power[2])) Domoticz.Debug('DebugOnForText: ' + str(onfortext)) ontodaytext = datetime.timedelta(seconds=int(power[3])) Domoticz.Debug('DebugOnTodayText: ' + str(ontodaytext)) ontotal = int(power[4]) Domoticz.Debug('DebugOnTotal: ' + str(ontotal)) ontotaltext = datetime.timedelta(seconds=int(power[4])) Domoticz.Debug('DebugOnTotalText: ' + str(ontotaltext)) totalmw = int(float(power[9]))/1000 Domoticz.Debug('DebugTotalkWh: ' + str(totalmw)) threshold = int(power[10])/1000 Domoticz.Debug('DebugThreshold: ' + str(threshold)) Devices[5].Update(0,"On for: "+ str(onfortext) + "<br>" + "On today: " + str(ontodaytext) + "<br>" + "On total: " + str(ontotaltext) + "<br>" + "Total kWh: " + str(totalmw) + "<br>" + "Standby threshold: " + str(threshold) + "<br>" + "Last change: " + str(lastchange)) if Parameters["Mode5"] == "YES": Domoticz.Debug("* Device 5 update called *") if threshold == int('8000')/1000: Devices[7].Update(1,"10") Domoticz.Debug("Standby: 'Default (8)'") else: Devices[7].Update(1,"20") Domoticz.Debug("Standby: 'Auto'") def updStatus(status): Domoticz.Debug("* updStatus called *") if not status: Domoticz.Error('False updStatus: ' + str(status)) return try: istate = int(status[0:1]) except ValueError: Domoticz.Error('Except updStatus: ' + str(status)) return Domoticz.Debug('DebugStatus: ' + str(status) + ' iState: ' + str(istate)) if istate == 1: if (1 in Devices): if Devices[1].nValue == 0 or Devices[1].nValue == 1: Domoticz.Debug("* Device 1 update called *, nValue: " + str(Devices[1].nValue) ) Devices[1].Update(1,"On") Domoticz.Debug("Device 1 updated to " + str(istate) + ", nValue: " + str(Devices[1].nValue) + " sValue: " + Devices[1].sValue) Domoticz.Debug("* Device 6 update called *, nValue: " + str(Devices[6].nValue) ) Devices[6].Update(10, "10") Domoticz.Debug("Device 6 updated to " + str(istate) + ", nValue: " + str(Devices[6].nValue) + " sValue: " + Devices[6].sValue) elif istate == 0: if (1 in Devices): if Devices[1].nValue == 1: Domoticz.Debug("* Device 1 update called *, nValue: " + str(Devices[1].nValue) ) Devices[1].Update(0,"Off") Domoticz.Debug("Device 1 updated to " + str(istate) + ", nValue: " + str(Devices[1].nValue) + " sValue: " + Devices[1].sValue) Domoticz.Debug("* Device 6 update called *, nValue: " + str(Devices[6].nValue) ) Devices[6].Update(0, "0") Domoticz.Debug("Device 6 updated to " + str(istate) + ", nValue: " + str(Devices[6].nValue) + " sValue: " + Devices[6].sValue) elif istate == 8: if (1 in Devices): if Devices[1].nValue == 0 or Devices[1].nValue == 1: Domoticz.Debug("* Device 1 update called *, nValue: " + str(Devices[1].nValue) ) Devices[1].Update(1,"On") Domoticz.Debug("Device 1 updated to " + str(istate) + ", nValue: " + str(Devices[1].nValue) + " sValue: " + Devices[1].sValue) Domoticz.Debug("* Device 6 update called *, nValue: " + str(Devices[6].nValue) ) Devices[6].Update(20, "20") Domoticz.Debug("Device 6 updated to " + str(istate) + ", nValue: " + str(Devices[6].nValue) + " sValue: " + Devices[6].sValue) if Parameters["Mode1"] == "YES": Domoticz.Debug("* Device 2 update called *") power = status.split('|') if Parameters["Mode1"] == "YES": currentmw = round(int(power[7])/1000) Domoticz.Debug('DebugkWh: ' + str(currentmw)) todaymw = int(power[8])/1000 Domoticz.Debug('DebugtoDay: ' + str(todaymw)) Devices[2].Update(0,str(currentmw) + "; " + str(todaymw)) # Synchronise images to match required Logo def UpdateImage(Unit, Logo): Domoticz.Debug("* updateImage called *, unit: " + str(Unit) ) Domoticz.Debug("Device current logo : " + str(Devices[Unit].Image) ) Domoticz.Debug("Device should have logo: " + str(Images[Logo].ID) ) if (Unit in Devices) and (Logo in Images): if (Devices[Unit].Image != Images[Logo].ID): Devices[Unit].Update(nValue=Devices[Unit].nValue, sValue=str(Devices[Unit].sValue), Image=Images[Logo].ID) Domoticz.Debug("Device " + str(Unit) + " image updated to " + Logo) return # Generic helper functions def LogMessage(Message): Domoticz.Debug(Message) def DumpConfigToLog(): for x in Parameters: if Parameters[x] != "": LogMessage( "'" + x + "':'" + str(Parameters[x]) + "'") LogMessage("Device count: " + str(len(Devices))) for x in Devices: LogMessage("Device: " + str(x) + " - " + str(Devices[x])) LogMessage("Internal ID: '" + str(Devices[x].ID) + "'") LogMessage("External ID: '" + str(Devices[x].DeviceID) + "'") LogMessage("Device Name: '" + Devices[x].Name + "'") LogMessage("Device nValue: " + str(Devices[x].nValue)) LogMessage("Device sValue: '" + Devices[x].sValue + "'") LogMessage("Device LastLevel: " + str(Devices[x].LastLevel)) LogMessage("Device Image ID: '" + str(Devices[x].Image) + "'") return def main(): import argparse parser = argparse.ArgumentParser(description='WeMo Insight control module for Python') parser.add_argument('action', choices=['on', 'off', 'status', 'name', 'signal', 'params', 'autopowerthreshold', 'setpowerthreshold', 'resetpowerthreshold'], help='Action') parser.add_argument('ip', help='IP address') parser.add_argument('port', nargs='?', default='49153', help='Port') args = parser.parse_args() IP=args.ip PORT=args.port insight = wemoInsight(IP, PORT) if args.action: print(insight.action(args.action)) if __name__ == '__main__': main()
- WeMoInsight.zip
- (6.14 KiB) Downloaded 183 times
Jump to
- General
- ↳ News & Updates
- ↳ General Discussion
- ↳ Bugs and Problems
- ↳ Other questions and discussions
- ↳ Suggestions
- Domoticz
- ↳ Installation, Compiling, Permissions, Security and Starting
- ↳ Cameras
- ↳ Switches and Scenes
- ↳ Utility
- ↳ Temperature and Weather
- ↳ Heating/cooling
- ↳ OpenTherm gateway
- ↳ Evohome
- ↳ Third party and supplementary tools
- ↳ Android
- ↳ iOS
- ↳ Windows
- ↳ Kodi (XBMC)
- ↳ Domoboard
- ↳ Dashticz
- ↳ Bugs
- ↳ Feature requests
- ↳ How-tos
- ↳ Node-RED
- ↳ Design, usability and languages
- ↳ Language / Translation
- Scripting & automation
- ↳ dzVents
- ↳ Bugs
- ↳ Examples & Solutions
- ↳ LUA
- ↳ Bash / PowerShell / Batch etc.
- ↳ Blockly
- ↳ Python
- ↳ PHP and all others
- Hardware and Protocols
- ↳ MQTT Auto Discovery
- ↳ Z-Wave
- ↳ Device information
- ↳ Zigbee
- ↳ Speech & Voice Systems
- ↳ 433 & 868 transceiver
- ↳ RFLink Transceiver
- ↳ Rfxcom Transceiver
- ↳ DIY Hardware and Protocols
- ↳ ESP8266
- ↳ PiFace
- ↳ Raspberry Pi GPIO ( WiringPi )
- ↳ MySensors
- ↳ 1-wire
- ↳ Others
- Community
- ↳ Sales, Deals and Bargains..
- ↳ Deals & bargains
- ↳ Forum feedback
- ↳ Show your projects
- ↳ Projects on other sites
