Dashticz - Module - Garbage collector Topic is solved
- Luxtux
- Domoticz version: 2021.1 β
Re: Dashticz - Module - Garbage collector
Yeah i tried that no luck. Try it for yourself:
https://wedevise.nl/dashticz/ical/demo/ ... om/bin.ics still just returns []
- Domoticz version: 3.7067
Should work now, could you try again?Luxtux wrote: ↑Monday 14 August 2017 21:10 Yeah i tried that no luck. Try it for yourself:
https://wedevise.nl/dashticz/ical/demo/ ... ns/bin.ics still just returns []
Edit, I see you're from Luxembourg and speaks French, would you like to check the French translations?
(You should create an account on lokalise.co so I can give you access to the project.. )
- Luxtux
Ah well look at that I hope you didn't have to change to much to get it to work
Yeah I speak French but my written isnt great but ill give it a go
Hi is it possible to add a *.ics file? because at Hellendoorn i can download a *.ics file.
Yes it is, you can enter this url in the settings-popup... or use:
config['garbage_company'] = 'ical';
config['garbage_icalurl'] = 'ENTER THE URL';
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
Great, but the problem is that the link is hidden and it popups a download screen.robgeerts wrote: ↑Wednesday 16 August 2017 10:25 Yes it is, you can enter this url in the settings-popup... or use:
config['garbage_company'] = 'ical'; config['garbage_icalurl'] = 'ENTER THE URL'; config['garbage_zipcode'] = ''; config['garbage_street'] = ''; config['garbage_housenumber'] = '';
maybe you could host the downloaded-file on a webserver?
- Luxtux
Me again, its like you will never get rid of me again
I think your server app https://wedevise.nl/dashticz/ical/demo/?url= is not set to deal with unicode characters, which with French words is unbelievably annoying but needed. as you can see below my webserver is able to encode in utf-8 but the input coming back is not utf-8.
here is what happens when i look at the output of the webdevise.nl outptut. as you can see its having trouble displaying any unicode characters.
Refresh
Should work now..
Should work now..
- DewGew
- Domoticz version: V4.10618
Is there a problem with google ical urls for garbage function?
I dont get any output on https://wedevise.nl/dashticz/ical/demo/?url=.
Could you send me a complete url?
I am lost; I am trying to setup the garbage collector. I have red the whole threat and I got the error "Loading". Copied the latest master files from gifthub, but I am not able to get it working. I think I need to do the following:
where xxxx in filled in with my home address.
Then I use 'garbage' in blocks, as a result the icon appears in my dashboard, but only "loading" appears
What am I doing wrong??
config['garbage_company'] = 'afvalwijzer';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = 'xxxx';
config['garbage_housenumber'] = 'xxx';
config['garbage_maxitems'] = '5';
Could you PM me your zipcode and housenumber so I can test with it?
- DewGew
Thanks, should be fixed now, please refresh!
- DewGew
Works now
when display the data for twente milieu, i get some strange text readings.
"Al al01 do papier d-week: Donderdag"
can't make any sense, could this text be altert.
Add this to config:
var trashnames = {}
trashnames['Al al01 do papier d-week'] = 'Papier';
- Domoticz version: DS213+
It seems garbage collecting in het Westland is not yet supported. May you add https://www.gemeentewestland.nl/afval/a ... eling.html in the future?
- Stefan
- EdwinK
- Domoticz version: BETA
I don't think that is possible, because the site doesn't generate a JSON or XML file to be used.
