Dashticz - [BETA] Function - Sortable blocks
raymond
- Domoticz version: V4.10232
Re: Dashticz - [BETA] Function - Sortable blocks
Yep done, I see the link has changed but it doesn't work unfortunately. Tried Firefox, Safari for both the installs, so on my Pi and Synology
robgeerts
- Domoticz version: 3.7067
Do you get any error in console?
Otherwise, let's have a teamviewer-session tonight...
raymond
Yes I get a bunch of errors in the console, but not sure where to look for and post.
robgeerts
Is it possible to have a Teamviewer-session?
(You can PM me your ID + pass if you have Teamviewer installed!)
raymond
Not tonight i'm afraid but thanks for offering
robgeerts
You can also select all the red lines in console en PM me those..
raymond
Not much to go on I'm afraid. I saw some errors on the security panel from Domoticz, and Buienradar is giving some errors. I switched off the SecPanel as this was one of the last additions I've made. The error remaining is:
Then it does throws some Buienradar stuff in, while this is working perfectly by the way:
It is irrelevant to the browser, OS or device I'm using, and in addition I've re-installed to beta from scratch on the Pi and on a Synology box to see if it makes any difference, which it doesn't. It seems like it cannot write the settings (??)
Anyway, I wouldn't stress it too much as I don't see anyone else with the problem. I don't want to keep you from doing other stuff
TypeError: can't access dead object
htmlPanel.js (line 1082, col 17)
<System>
TypeError: o is undefined
buienradar.min.js (line 1, col 8360)
TypeError: window.buienradar.api is undefined
2749812...2957303 (line 166, col 5)
TypeError: window.buienradar.controls is undefined
2749812...2957303 (line 304, col 25)
TypeError: window.buienradar.getParameterByName is not a function
ztorm
- Domoticz version: 3.8153
scrolling is back
robgeerts
@raymond and @ztorm,
I really would like to have a teamviewer session.
As I dont have any problems it's hard to fix it.
I would appreciate it if you could send me your teamviewer details bij PM..
raymond
@Rob,
Understood you cannot do anything when you don't have the error described.
I managed to get this out when I move a block:
The "Learn More" goes here: https://developer.mozilla.org/en-US/doc ... fined_prop
I doubt this helps though, so a TeamViewer might do the trick.
ReferenceError: reference to undefined property "returnValue"[Learn More] jquery.min.js:3:10101I doubt this helps though, so a TeamViewer might do the trick.
robgeerts
Indeed, it doesnt help me much
Could you send me your teamviewer credentials via PM?
h143
i have the same error wenn i want save it Chrome says
javascript:void(0);
and the next errorin the console:
javascript:void(0);
Uncaught TypeError: Cannot read property 'width' of undefined
at HTMLDivElement.eval (eval at globalEval (:8080/dashticz_v2/vendor/jquery/jquery.min.js:2), <anonymous>:72:47)
at Function.each (:8080/dashticz_v2/vendor/jquery/jquery.min.js:2)
at n.fn.init.each (:8080/dashticz_v2/vendor/jquery/jquery.min.js:2)
at saveBlocks (eval at globalEval (:8080/dashticz_v2/vendor/jquery/jquery.min.js:2), <anonymous>:43:20)
at HTMLAnchorElement.onclick (192.168.1.20/:1)
(anonymous)
each @ :8080/dashticz_v2/vendor/jquery/jquery.min.js:2
saveBlocks
onclick @ 192.168.1.20/:1
21:22:45.184 192.168.1.20/:72 Uncaught TypeError: Cannot read property 'width' of undefined
21:22:47.080 192.168.1.20/:72 Uncaught TypeError: Cannot read property 'width' of undefined
21:22:50.608 192.168.1.20/:72 Uncaught TypeError: Cannot read property 'width' of undefined
21:23:25.173 192.168.1.20/:72 Uncaught TypeError: Cannot read property 'width' of undefined
21:23:27.141 192.168.1.20/:72 Uncaught TypeError: Cannot read property 'width' of undefined
21:24:04.697 VM117:72 Uncaught TypeError: Cannot read property 'width' of undefined
at HTMLDivElement.eval (eval at globalEval (jquery.min.js:2), <anonymous>:72:47)
at Function.each (jquery.min.js:2)
at n.fn.init.each (jquery.min.js:2)
at saveBlocks (eval at globalEval (jquery.min.js:2), <anonymous>:43:20)
at HTMLAnchorElement.onclick ((index):1)
(anonymous) @ VM117:72
each @ jquery.min.js:2
saveBlocks @ VM117:43
onclick @ (index):1
21:24:14.347 VM117:72 Uncaught TypeError: Cannot read property 'width' of undefined
onclick @ (index):1-
robgeerts
Are you on iOS?
h143
No that was on windows 10
poudenes
- Domoticz version: 3.8993
Add the line in top of the config.js. Did a git pull to get latest beta.
I have multiple screens, maybe that is the problem. But i can't move things at all haha
robgeerts
Do you get any console error?
poudenes
no, nothing, just my current Dashticz beta screens...
raymond
Are you using the old definition for getting into Edit mode?
This:
var _EDIT_MODE = true;Code: Select all
config['edit_mode'] = 1;Code: Select all
var config = {}-
poudenes
This was the solution thanks !!raymond wrote: Thursday 24 August 2017 10:29it should be in the list afterCode: Select all
config['edit_mode'] = 1;in CONFIG.jsCode: Select all
var config = {}
Users browsing this forum: Google [Bot] and 0 guests
