I'm new to the site and to Domoticz. After installing on a Pi, I'm already a big fan.
But I do have a couple of questions if anyone can help.
Is there a way to send out KNX IP telegrams from domoticz?
Assuming I have a KNX IP router, and Domoticz can send out (and listen for) a KNX IP telegram (pretty sure it's UDP), this wouldn't need any hardware development.
Am I correct in that Domoticz can already send out UDP packets?
If so, is it possible to set up / define a custom packet.
There may be more to it than I think, but to my mind it shouldn't be that hard. Just a matter of sending out a packet.
I'm not thinking of a full blown KNX system, just a few devices.
Can anyone help?
I haven't come across much about KNX and Domoticz of the forum.
KNX IP Telegrams possible from Domoticz?
Lazerjules
- gizmocuz
Re: KNX IP Telegrams possible from Domoticz?
The AppLamp hardware is using UDP datagrams....
You could try making your own KNX hardware class... i know FHEM is supporting that, maybe peak a little here how everything is working?
/Rob
/Rob
BaseRabbit
I try to connect to the KNX bus as well. There is an USB KNX Adaptor
http://busware.de/tiki-index.php?page=TUL
which should work with FHEM, but seems to be a long way flashing to USB to FHEM to Domoticz.
Is someone using this adaptor directly from Domoticz?
-HL
-HL
