Alternative for goto in lua?
I have a lua script that i want to convert but this script contains goto. Very simple like if device = 0 then goto :name:
This means that the rest in the script between this line and :name: a bit further in the script is skipped.
I know that my script is not very good and i could make it work like that so i wonder if this is also possible within dzVents.
- Domoticz version: Stable
Re: Alternative for goto in lua?
please past your script here, much easier to advise on
Euww. You should never have a need for a goto. There's never an excuse either.
- Domoticz version: 2022.2
Do not agree. In some cases a goto takes care of much easier to read code instead of a big if statement or so.
Besides that things like break in a case are basically goto's as well.
Verstuurd vanaf mijn SM-G930F met Tapatalk
The breaks are part of the construct but I don't like them either. But I'm not gonna argue on this one. Gotos are bad and should be avoided and fortunately almost all modern languages don't have them.
I understand the discussion but all i did was ask if it is possible within dzVents
I am used to program PBX's and some do have a visual IVR (GUI) and goto's are very common.
You cannot always program everything in the best way, sometimes quick and dirty is well enough.
I do not mind to discus about'it, dont get me wrong.
please paste example script here. There is probably GOTO statement in LUA http://lua-users.org/wiki/GotoStatement, but in structured programming languages, it is usually not used, or not available at all. My last use of GOTO statement was in Basic programming some tenths years ago
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
Ok finaaly got some time.
I have this script now and i want to add two switches which will override the humidity part.
When i use a goto then i just skip the humidity part if configure above it.
active = true,
timer = {'every minute'}
execute = function(domoticz)
local bathroomSensor = domoticz.devices('Badkamer')
if bathroomSensor.humidity >= 10 and bathroomSensor.humidity <= 75 then
domoticz.devices('Mechanische ventilatie').switchSelector(10)
elseif bathroomSensor.humidity >= 76 and bathroomSensor.humidity <= 85 then
domoticz.devices('Mechanische ventilatie').switchSelector(20)
elseif bathroomSensor.humidity >=86 and bathroomSensor.humidity <= 100 then
domoticz.devices('Mechanische ventilatie').switchSelector(30)
In this case, I will write script like this:
Indenting code by space or tab maintains better readability in nested control structures like functions, if..then..else..end conditions etc.
It is also good idea, in case of time script, to not update ventilator device every run (sure, if not overriden) to same value. Conditional update - like compare ventilator current settings with new value is better:
local LOGGING = true
active = true,
-- store override devices to variables - for better readability
local override1 = domoticz.devices('switch').state
local override2 = domoticz.devices('switch2').state
-- ventilator device variable - for better readability and easier change device name in one place etc.
local ventilator = domoticz.devices('Mechanische ventilatie')
if override1 == 'On' or override2 == 'On' then
-- for debugging purpose, log also if overriden
if LOGGING then
domoticz.log('Override active')
-- if not override, do something
ventilator.switchSelector(10)
ventilator.switchSelector(20)
ventilator.switchSelector(30)
active = true,
if LOGGING then
local ventCurrent = ventilator.level -- current level
local ventNew = 0 -- variable for new level
ventNew = 10
ventNew = 20
ventNew = 30
if ventCurrent ~= ventNew then
-- compare current level with new, and then switch or not
domoticz.log('Changing level from: ' .. tostring(ventCurrent) .. ' to: ' .. tostring(ventNew))
ventilator.switchSelector(ventNew)
-- not switching
if LOGGING then
domoticz.log('Level is same')
My toys:
Ok, i had a go with this script.
The humidity part works fine but the override part not.
What i did it that the two switches will set the switchlevel to 20 and 30 and when these are off it is set to switchlevel 10 just like when the humidity level is below 75.
I cannot get that working at all.
I tried creating a variable like the other part but i keep getting errors.
Can you help me out with this?
OK, post script here.
My toys:
I used your script
Override 1 and 2 need to set switchselector(20) and switchselector(30)
Somehow it keeps saying level is same and keeps switching every minute.
active = true,
if LOGGING then
ventNew = 10
ventNew = 20
ventNew = 30
-- not switching
if LOGGING then
Aah, just for sure if I understand correctly:
- override switches are 2 simple On / Off switches ?
- override should happen when any of switches is On ?
- one override switch should set 'Mechanische ventilatie' selector switch manually to 20, and second manually to 30 ?
- if both override switches are off set 'Mechanische ventilatie' selector switch manually to 10
- automatic control by humidity sensor 'Badkamer' should be done at which situation ?
My toys:
- override switches are 2 simple On / Off switches ? Yes they are
- override should happen when any of switches is On ? Yes
- one override switch should set 'Mechanische ventilatie' selector switch manually to 20, and second manually to 30 ? Yes
- if both override switches are off set 'Mechanische ventilatie' selector switch manually to 10 Yes as that is the default setting
- automatic control by humidity sensor 'Badkamer' should be done at which situation ? This should happen when both switches are off
So the last two questions are like this:
Default 'Mechanische ventilatie' is running on level 10 and is controlled by humidity as you know.
When one of the two switches is used then it must be set to level 20 or level 30 and not controlled by humidity anymore.
If those two switches are off then it wil return to humidity control.
New script for you
One more idea - there is a option to change script from time based (every min) to device based (change of switches or humidity) - both has pros and cons
active = true,
logging = {
level = domoticz.LOG_INFO,
local ventNew = 10 -- variable for new ventilator level, default is 10
local override = false -- helper variable for logging - set to true later if override active
if override2 == 'On' then
-- first check override2 - if both switches On, switch2 has higher priority -> higher ventilator
override = true
ventNew = 30 -- override to 30
elseif override1 == 'On' then
-- status override1 switch
override = true
ventNew = 20 -- override to 20
-- if not override, check humidity
-- dotn check range 10-75, level defaults to -> 10
-- if bathroomSensor.humidity >= 10 and bathroomSensor.humidity <= 75 then
-- ventNew = 10
ventNew = 20
ventNew = 30
if LOGGING then
if override then
domoticz.log('Override active to ' .. tostring(ventNew))
-- not switching
if LOGGING then
My toys:
Thanks very much. I am going to have a good look on this script as what i see is logical and i can read it but somehow i am not capable enough at the moment to come up with this by my self yet.
But i think i just need some time to get used to dzVents.
Thanks again, you are a hero.
You are welcome
My toys:
