Neo Coolcam Door sensor not working
prekz
Post by prekz »
Hi guys,
I'm pretty new to Domoticz and i just bought a Neo Coolcam Doorsensor and a Neo Coolcam PIR. The PIR is working very fine.
I tried the include option in domoticz for the door sensor en first i thought it was ok.
I have a device id 0x000 and that's not looking good, i just found one topic on this forum with the same issue:
viewtopic.php?f=24&t=15265 i did an exclude and include again but i have the same problem.
I'm not 100% sure if this is a problem or not.
But i'm working on a blocky script when the door sensor is open that the light turns on. (see picture below). But i'm not sure wich device i need (see second picture) so i dont know if the device is working properly.
This is the device in the hardware tab (device 0x6)
As you can see the doorsensor is not wel recognized.
Is there anything i can do?
Doler
Re: Neo Coolcam Door sensor not working
Post by Doler »
I have 4 Neo Coolcam doorsensors working without a problem. Got a defective one once too, but got it replaced. Try to complain at the supplier.
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
prekz
Post by prekz »
I don't think it's defective because it's showing up in domoticz (not well but it is showing).
Second problem with a replacement, i bought this item 2 months ago, i just found time to play with these neo coolcam PIR and door sensor :P
