Dashticz - Module - Garbage collector Topic is solved
robgeerts
- Domoticz version: 3.7067
Re: Dashticz - Module - Garbage collector
Could you remove your cache or try another browser?
- DewGew
- Domoticz version: V4.10618
Still not ok, maybe its my setup see my config...robgeerts wrote:Could you remove your cache or try another browser?
robgeerts
Your config is ok.
I tested and it worked. Maybe you get another error in your console (f12) ?
Otherwise, we can have a teamviewer-session tonight..
- DewGew
There is no errors in the console.robgeerts wrote: Wednesday 09 August 2017 9:35 Your config is ok.
It´s not working garbage plugin. But I can get my garbage calender work with ' var calanders ={} '
robgeerts
Avalex works in latest beta!
config['garbage_company'] = 'avalex';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = '2286lz';
config['garbage_street'] = '';
config['garbage_housenumber'] = '341';
- Dynamic
- Target OS: -
I can't get the Garbage collector to work.... I entered all the parameters using the webbased config-utility, but nothing is displayed. Is there something else I should activate/add?
FYI: I'm using 'Twente Milieu'.
This is my config-file:
config['garbage_company'] = 'twentemilieu';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '7544 XX';
config['garbage_street'] = 'STRAATNAAM';
config['garbage_housenumber'] = '1';
config['garbage_maxitems'] = '3';
config['garbage_width'] = '12';- EdwinK
- Domoticz version: BETA
Did you add 'Garbage' in a column?
columns[3] = {};
columns[3]['blocks'] = [185,buttons.webcam,buttons.moon,'garbage'];
columns[3]['width'] = 2;Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
- Dynamic
- Target OS: -
Nope... I was only using the webconfig-utility. I'll try to add this to the CONFIG.js.
Edit: some progress. I can see the trash-can icon, but it keeps saying 'laden' (loading).
robgeerts
Try removing the space in the zipcode..
- Dynamic
- Target OS: -
The 'loading' has disappeared, but now the text is a little bit strange (see screenshot).
- 11-8-2017 14-44-54.png (54.3 KiB) Viewed 5360 times
robgeerts
You could add this to config.js:
var trashnames = {}
trashnames['En zl02 wo gft oneven'] = 'GFT';
trashnames['En al03di vec'] = 'Watisdit?';
trashnames['En zl02 wo rest even'] = 'Restafval';
- Dynamic
- Target OS: -
Yep, that's a nice workaround.
- madpatrick
- Domoticz version: 2026.1
IS it possible to get the garbage to work for Hellevoetsluis ?
Looks like it is possible, but how do i put this in the config ?
http://www.gemhellevoetsluis.nl/applica ... l?OpenForm
- CRaZee
- Domoticz version: V3.8153
Ubuntu on Cubietruck
robgeerts
Hellevoetsluis is not possible.
The are not returning the right format..
HeezeLeende is added to latest beta, BUT, for some reason the calendar they return in the ical-url is empty...
(Also when I download the ical from the website)
In both cases you can create an ical yourself and use the ical-option..
config['garbage_company'] = 'heezeleende';
config['garbage_zipcode'] = '5591 HS';
config['garbage_housenumber'] = '2';
config['garbage_maxitems'] = '5';
h143
Is it posible to ad http://afvalkalender.leek.nl/afvalkalen ... chbox.html to dashticz?
robgeerts
Not directly but you can do it like:
1.) Enter your zipcode
2.) On the resultpage, push with you right mousebutton on 'Persoonlijke afvalkalender' and copy url
3.) In Dashticz, choose the ical-option and paste this url in the ical-url-field.
- Luxtux
- Domoticz version: 2021.1 β
Hey,
Im trying to add the ICAL of Luxembourg city. here an example of a file:
https://service.vdl.lu/hygiene/calendri ... er=complet.
I didnt see anything appear in Dashticz. so I had a look at your garbage.js file and noticed that all ical files get send to
https://wedevise.nl/dashticz/ical/demo/?url= .
so i added the the url of the garabage collection in my city. This didn't return anything. Then i tried some other urls that were in the garabage.js e.g.
only [] is returned. is this webservice still working?
url where you can find examples of the calendar:
https://www.vdl.lu/vivre/domicile-au-qu ... -collectes
testuser@testserver~$ curl -s 'https://wedevise.nl/dashticz/ical/demo/?url=https://calendar.google.com/calendar/ical/o44qrtdhls8saftmesm5rqb85o%40group.calendar.google.com/public/basic.ics'
[]testuser@testserver~$url where you can find examples of the calendar:
robgeerts
Are you able to save the ical you get as download to a webserver?
Then you could enter that url after: https://wedevise.nl/dashticz/ical/demo/?url=
The url you check is indeed not working
