Blockly script not runing
R0yk3
Post by R0yk3 »
Rasp pi 3
Domoticz 3. 8258
I have this (i thougt) very simple script;
https://prnt.sc/g5xcuo
3 switches, all the switches work, they go on an of as planned. I use 'zononder' (sundown) as a switch because i want it to respond 30 minutes before sundown.
This means when al the criteria is met, i want to turn on my livingroom light.
It looks very simple, but it does not work. i tried it by writing a log message that does not work either :?:
I have respond to all triggers active.
no error in the log. :( either.
I somebody can make in in dzvents i do not mind :P
but this should just work.. ??
Raspberry PI 3, raspbian, ZwaveMe, RFLink
StanHD
Re: Blockly script not runing
Post by StanHD »
Have you checked that the "Event active" is checked for the Blockly? (I agree, it should work).
Sent from my SM-T820 using Tapatalk
Python:- Broadlink RM2, Sonos
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Use the IF constructor without the blue star,
in case there is no Else branch
dressie
Domoticz version: V2020.2
Post by dressie »
Domosapiens wrote:Use the IF constructor without the blue star,
Yep, that's the problem in your blocky script!
R0yk3
Post by R0yk3 »
StanHD, yes the event is active,
I will try it without the blue star.
I had this option because the script was longer with several if events (dimming the light at certain times) but did not work ether so i stripped it down. But i wil try this.
thank you.
R0yk3
Post by R0yk3 »
This was it. Thank you guys!!
