if device = on and between specified time interval
TheCondor
Post by TheCondor »
Hello, i'm trying a very simple script but without success. I need to turn on a light "Bano Lampada" when the PIR is ON (Sensore Movimento) but only during the night, suppose an interval between 23:00 and 07:00.
That's what i do, but it doesn't works. If i remove the 'time' part works fine obviously... so i'm not using correctly the time function of dzvents.... any help is very appreciated, thanks in advance.
	active = true,
		devices = {
            'Sensore Movimento'
	execute = function(domoticz, Bagno)
			if domoticz.devices('Sensore Movimento').state == 'On' then
			    if (domoticz.time.hour > 23 and domoticz.time.hour < 7) then
                    domoticz.devices('Bagno Lampada').switchOn().forMin(2)
markjgabb
Domoticz version: 3.8153
Re: if device = on and between specified time interval
Post by markjgabb »
Think you need to use or. As the time can't be both after 11 and before 7 at the same time
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
bimse
Domoticz version: Model 3
Post by bimse »
[Try this
	active = true,
		devices = {
            			['Sensore Movimento'] = {'at 23:00-07:00'}
[/quote]
Translated with google
TheCondor
Post by TheCondor »
Awesome, both works fine, thanks and sorry for the dummy question!!!
Users browsing this forum: Ahrefs [Bot] and 1 guest
