Trigger every 5 mintes after midnight if device is off
DespyNL
Domoticz version: v4.9701
Post by DespyNL »
I am new to dzVents and it looks very promising. I've started migrating some lua script to dzVents, but I am experiencing some difficulties.
By default I would like to switch off the lights after midnight, but only when the TV is off. If the tv is on, the lights should stay on and the script has to check again in 5 minutes. I guess the script should be triggered at midnight, every 5 minutes and only when the lights are on. Is this possible with dzVents?
Its a waste of time to run the script if its past midnight and the lights are already out
	active = true,
		timer = {
			'at 00:00 every 5 minutes'
		-- + only if device light state is on
		-- is there any way?
Nautilus
Re: Trigger every 5 mintes after midnight if device is off
Post by Nautilus »
Sorry for bit of an off-topic (as I don't use dZvents) but I cannot see why you don't put this to a device script that triggers when TV is turned off (with a second condition for a desired time frame)? You can of course add a delay too if you do not want the lights to turn off immediately...
freakshock
Post by freakshock »
I'm new to dzVents as well, but it should be something like this I think:
   active = true,
      timer = {
         'at nighttime 00:00 every 5 minutes' --added at nighttime because else it would continue forever I think
   execute = function(domoticz)
   	if (domoticz.devices('TV').state == 'Off' then
		    domoticz.devices('Light1').switchOff()
		    domoticz.devices('Light2').switchOff() --or insert a group with all lights here
dannybloe
Post by dannybloe »
This will not work like this. 'at nighttime' is a period (from sunset-sunrise) but 00:00 is a moment. So that's a contradiction. So in your case I would do something like this:
   active = true,
      timer = {
         'every 5 minutes at 00:00-06:00'
      	-- do your thing
But, why don't you make a script that is triggered when the tv goes off?
   active = true,
      devices = {
      	'TV' = {'at 00:00-06:00'}
   execute = function(domoticz, tv)
   	if (tv.state == 'Off) then
Unless of course you don't get an event when the tv is turned off.
