LUA script that talk to me when a virtual switch is ON
blaisabcde
Post by blaisabcde »
Let me share one of my LUA script that talk to me when a virtual switch is ON :
-- Replace "Garbage" by your virtual lightswitch device name
-- Make sure http://www.domoticz.com/wiki/Talking_Domoticz is installed
if (devicechanged['Garbage'] == 'On') then
	os.execute('espeak "Bring the garbage out"')
Feel free to do some improvement to it and post it on the forum =)
The next step would be to create a script that tell me the current weather via espeak.
Pjedr
Re: LUA script that talk to me when a virtual switch is ON
Post by Pjedr »
My text to speech script by google via Internet, really good audio:
(Limit = 100 characters)
#!/bin/bash
if [ -e "/var/ramdrive/domoticz" ]; then TEMPDIR="/var/ramdrive"; else TEMPDIR="/home/peter/"; fi; echo "`date` $*" >> ${TEMPDIR}/${0##*/}.log;
exec 200>${TEMPDIR}/${0##*/}.lock || exit 1; flock -x 200 || { echo "ERROR: flock() failed." >&2; exit 1; }
say() { local IFS=+;/usr/bin/mplayer -ao alsa -really-quiet -noconsolecontrols "http://translate.google.com/translate_tts?tl=nl&q=$*"; }; say $*; flock -u 200
I included locking mechanism, cause muliple messages were at the same time.
Pjedr
Post by Pjedr »
Just call the script with the text as parameters from your lua or domoticz_main as below.
if [ "$status" = "On" ]; then        nohup ${SCRIPTSDIR}/Speech.sh "${devname} is aangezet" 2>/dev/null &
 nohup ${SCRIPTSDIR}/JSTxWrapper.sh "Domoticz OSD melding: ${devname} is aangezet" 6 2>/dev/null &
 nohup ${SCRIPTSDIR}/Telegram.sh $msgto "Domoticz melding: ${devname} is aangezet" 2>/dev/null &                                               #espeak -v nl "${devname} is aangezet"
exit; fi;        if [ "$status" = "Off" ]; then        nohup ${SCRIPTSDIR}/Speech.sh "${devname} is uitgezet" 2>/dev/null &
 nohup ${SCRIPTSDIR}/JSTxWrapper.sh "Domoticz OSD melding: ${devname} is uitgezet" 6 2>/dev/null &
 nohup ${SCRIPTSDIR}/Telegram.sh $msgto "Domoticz melding: ${devname} is uitgezet" 2>/dev/null &
 #espeak -v nl "${devname} is uitgezet"
exit; fi;
espeak, telegram, jstx lines can be removed, you need only speech.sh,nohup and & is used to start it in separate silent processes so domoticz does not slow down. Jstx is used to send the text to my philips tv screen.
blaisabcde
Thank, indeed your solution is much better and the voice as well.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
google voice is not usable any more.
New solution here : https://www.domoticz.com/wiki/Talking_Domoticz
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Is there a way to send the "text" as part of the script, rather than having to do individual scripts per device?
For example, edit a button when it goes ON it calls a script like this: scriptt://espeak "something in on"
I tried but says it cannot find a script. I thought about linking to espeak inside the script folder but couldn't find the espeak file that executes... any ideas welcome.
11101101 - www.machinon.com
