Have a read through here: https://www.domoticz.com/forum/viewtopic.php?t=8495
And also here
https://www.domoticz.com/forum/viewtopi ... 28&t=15822
They are talking about updating the status of a virtual switch without triggering it the events linked to it.
If you use:
commandArray["UpdateDevice"] = "54|0|Off"
commandArray["UpdateDevice"] = "54|1|On"
where 54 = IDx of the switch
where 0 is the N value
where "Off" is the S value
It should update the status of the switch without triggering any events.
Do not trigger action if...
sion
Re: Do not trigger action if...
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
dannybloe
This is quite interesting. I'll add a silent argument to the switchOn() and switchOff() methods:
In the meantime you can do this:
Do NOT fiddle directly with commandArrays in dzVents as it most certainly will give you nasty side effects! Always use the api (domoticz.sendCommand() or device.update())
myDevice.switchOn(true) -- will not trigger events
mySwitch.update(0, 'Off')
mySwitch.update(1, 'On')
bimse
- Domoticz version: Model 3
Will there be the same option with domoticz.devices('Security Panel').armAway()
Translated with google
