dzVents.lua not found
I'm facing problems trying to get dzVents 2 up and running.
Running on Synology NAS with Domoticz 3.8143 beta and Python plugin.
The error is:
2017-07-27 22:40:19.984 Error: EventSystem: in /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: cannot open /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua: No such file or directory
I don't have a dzVents folder in the scripts directory. Also searched my whole system for dzVents but didn't get any match.
Not sure how to proceed.
The error is:
Re: dzVents.lua not found
That's an issue with the NAS package. More people have reported it.
Thanks danny. I'll wait for a new build and a solution. Do you know if the maintainer of the NAS package is informed about this issue?
- jumbotroll
You can try to reinstall the package.bramski wrote:I'm facing problems trying to get dzVents 2 up and running.
The error is:
Take backup of db and scripts, then remove the package from package center and reinstall.
Worked here...
@DS712:/usr/local/domoticz/var/scripts/dzVents/runtime$ ls
device-adapters EventHelpers.lua persistence.lua todo.md
Device.lua HistoricalStorage.lua tests Utils.lua
Domoticz.lua integration-tests TimedCommand.lua Variable.lua
dzVents.lua misc Time.lua
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
@jumbotroll @dannybloe
Sorry to bother you guys again, but I'm still struggling with getting dzVents working in the Synology build.
I am one step further by following the suggestion of jumbotroll. I deinstalled the package and reinstalled it again and now I have the folder /usr/local/domoticz/scripts/var/dzVents.
However when starting domoticz I get a lot of errors related to dzVents:
- Spoiler: show
- Spoiler: show
Not exactly sure what is happening here. So, what I would do is remove the scripts folder from your install (make a copy if you have custom scripts). Then get a copy of that folder from github (master/stable) and put it in place. Start Domoticz and see if you still get those errors. If you do than I have no idea what is causing this. But, if you don't get those errors then move you event scripts back to the proper location. But be sure that dzVents scripts (if you have any) should only be in scripts/dzVents/scripts. Carefully check this. Make sure NOT to put non-dzVents lua scripts in there as it will break stuff. Classic Lua should be placed in scripts/lua.
Thanks dannybloe. Exactly what you descibed is also what I tried yesterday, however this makes no difference. Just to be sure I tried again. Removed dzVents directory. Made sure I was on the master branch. Did a git pull to get fresh changes and moved that directory to the domoticz installation directory. Still have all those errors with "too many C levels".
I am curious if somebody has dzVents running on Synology at all. Maybe it is some issue with the C compiler in Synology architecture.
I'd try it with the entire script folder. Not just the dzVents folder.
Still the same error Danny unfortunately. Seems some endless recursion somewhere, but I don't know that much about LUA and C internal workings.
Could it be that those paths are symlinks?
For example the whole domoticz installation is symlinked from /volume1/@appstore/domoticz to /usr/local/domoticz
All LUA files are included from /usr/local/domoticz, maybe it keeps searching for the files this way until it hits 200 iterations and crashes.
- EdwinK
- Domoticz version: BETA
After removing Domoticz and restarting my Synology before reinstalling Domoticz again, I found that the script dzVents.lua is now present.
@EdKo66, @dannybloe, Yes it was also in place for me after reinstalling. However I got all those errors "too many C levels (limit is 200)", so it still wasn't working.
But I have good news. Finally got it resolved.
I bought a Raspberry PI 3 to eliminate Synology as the root of the problem.
Installed domoticz on the device and copied the domoticz.db from my Synology.
Enabled dzVents and immediately got similar errors with the "too many C levels", which is an indication of endless resursion.
Turned out that I named the script in the inline editor "dzVents". This file is copied to "generated_scripts", but when it is initialized it gets the same name as the already existing dzVents.lua in the runtime folder, and causes a recursion loop this way.
Renamed the event to "test" and magically all my issues disappeared
Now I have domoticz running on the PI, not really sure if I leave it this way or migrate it back to synology.
I think I prefer to leave domoticz on the PI and don't pollute the NAS with all kind of packages which are not really related to NAS functionality.
Ah. Haha yeah we didn't anticipate this one!
Haha, yeah part of a developers live
Now I can finally rewrite some of my ugly unmaintainable LUA scripts to a much nicer syntax.
