Domoticz App
marcotrumpet
Re: Domoticz App
Post by marcotrumpet »
galadril wrote:you could do that if you like.
There are little things to fix.. tell me how to do that or I can write you what and were
Inviato dal mio iPhone utilizzando Tapatalk
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
We've a crowdin project for managing translations for both mobile apps:
https://crowdin.com/project/domoticz-for-android
bdormael
Re: Domoticz App
Post by bdormael »
Great version so far, few minor suggestions (apologies if already suggested before):
- more slim version of dashboard (smaller boxes, less scrolling)
- show temperature also on right side in case of temp sensors
- handle set points like dimmers for setting temp (no free text box but like how dimmers work now)
- for multi select switches or sec panel, make a separation between the selections and ‘favorite’ as it looks now that this is a selection as well
- ultimately an iPad version as well (make use of screen estate)
Verzonden vanaf mijn iPad met Tapatalk
galadril
Re: Domoticz App
Post by galadril »
Thanks for the feedback.
BTW i've also updated first post with all new screenshots.
Ill add 5 more beta testers end of this week...
marcotrumpet
Re: Domoticz App
Can't find the talk back string in crowding
bdormael
Re: Domoticz App
Post by bdormael »
Maybe one more thing:
All sensors are now shown as ON or OFF on the right side, it would be nice if it shows OPEN or CLOSED in case of contact sensors
galadril
Re: Domoticz App
Post by galadril »
ill see what i can do
tequila
Re: Domoticz App
Post by tequila »
Hey,
I am still having this weird and very annoing issue with actions being executed several times from the app.
From my experience this only happens with sripts that require some time (a couple of seconds) to run.
For example, I have a push on button defined that triggers 3 scripts.
When I use the button from Domoticz web interface, everything runs as expected - each of the 3 scripts is executed once; I receive 3 reports (each of the 3 scripts sends a report).
If I use the same button from the app, the log says I initiated the push 6 times!
And indeed, I am getting 18 (6*3) reports.
galadril
Re: Domoticz App
Post by galadril »
tequila wrote:Hey,
Can you see with the new debugging panel (under settings screen) if the action is also triggered multiple times from the app??
Because else it's probably a domoticz system issue (api maybe)
galadril
Re: Domoticz App
Post by galadril »
marcotrumpet wrote: Can't find the talk back string in crowding
It's there, under the settings translations:
https://crowdin.com/translate/domoticz- ... -it#q=talk
marcotrumpet
Re: Domoticz App
There is the right translation. Vote up the right one and down the other one now in use..
tequila
Re: Domoticz App
Post by tequila »
galadril wrote:
tequila wrote:Hey,
I am getting:
onButtonClick
set idx XX to ON
and I have been receiving all reports again and again unless
com.android.volley.TimeOutError appears.
So no, the debug doesn't show I would be pressing the button several times, but all reports are being sent until the above timeout error appears.
galadril
Re: Domoticz App
Post by galadril »
tequila wrote:I am getting:
onButtonClick
set idx XX to ON
I would guess that it's an domoticz / api issue, because the event only fire once in the app. So that one api call of me, internally in domoticz has issues with your script.
Maybe some of the domoticz dev's can assist you on that :(
tequila
Re: Domoticz App
Post by tequila »
okay, I understand. thanks mate.
bdormael
Re: Domoticz App
Post by bdormael »
Maybe a stupid question:
How do I enable notifications to work with the iOS app?
- I’ve enabled them in your app
- I’ve enabled gcm in Domoticz web app
- I’ve added a notification on a switch and enabled all
Now I don’t see any notifications coming on my iPhone
Sorry if this is a stupid question
galadril
Re: Domoticz App
Post by galadril »
bdormael wrote:Maybe a stupid question:
Sorry if this is a stupid questionk
This is not a stupid question..
1) You need the latest beta version of domoticz system!!! (them made changes to gcm/notifications for ios)
2) Enable GCM notifications on settings in domoticz system.
3) Open the app iPhone, check if notifications is enabled on the app.
4) The app should register itself automaticly on Domoticz, so with the latest beta you have a new settings screen called 'Mobile Devices' under more options, you should see your device registered there
5) Try a notification on a test switch with gcm enabled.
it should work.. if not, enable debugging on the debug panel in the app.. and we'll see what happens..
bdormael
Re: Domoticz App
Post by bdormael »
Cool, thx for the swift answer, working fine now (without sound)
tequila
Re: Domoticz App
Post by tequila »
onButtonClick
set idx XX to ON
Perhaps a stupid question - how do you actually call that action? I assumed that the domoticz app is based on json url commands.
I wanted to open an ticket in Git but when I do following:
curl 'http://USER:PASS@IP:PORT/json.htm?type=command&param=switchlight&idx=39&switchcmd=On'
It works as expected. So the domoticz app must be using something different than I thought it does.
In conclusion, I am not sure how to report that issue:-)
Cheers.
galadril
Re: Domoticz App
Post by galadril »
tequila wrote: In conclusion, I am not sure how to report that issue:-)
Cheers.
Maybe it'll improve if i make the timeout period longer on the data calls in the app......
galadril
Re: Domoticz App
Post by galadril »
bdormael wrote:- handle set points like dimmers for setting temp (no free text box but like how dimmers work now)
Ill have an improvement on set points for the next release with a minus+add button... for now
