In the calendar settings you can get a private-address... (this is a unique address wich u can use, but this way it is not discoverable by other users).
See screenshot below (the second option u have to use)
curl -v --cookie "RovaLc_inwoners={\"Id\":160266,\"ZipCode\":\"7731ZT\",\"HouseNumber\":\"84\",\"HouseAddition\":null,\"Municipality\":\"Ommen\",\"Province\":null,\"Firstname\":null,\"Lastname\":null,\"UserAgent\":\"\",\"School\":null,\"Street\":null,\"Country\":null,\"Portal\":null,\"AreaLevel\":5,\"City\":\"Ommen\",\"Ip\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners
* Trying 141.138.194.225...
* Connected to www.rova.nl (141.138.194.225) port 443 (#0)
* found 173 certificates in /etc/ssl/certs/ca-certificates.crt
* found 696 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_RSA_AES_256_CBC_SHA384
* server certificate verification OK
* server certificate status verification SKIPPED
* common name: www.rova.nl (matched)
* server certificate expiration date OK
* server certificate activation date OK
* certificate public key: RSA
* certificate version: #3
* subject: CN=www.rova.nl
* start date: Tue, 23 May 2017 06:01:00 GMT
* expire date: Mon, 21 Aug 2017 06:01:00 GMT
* issuer: C=US,O=Let's Encrypt,CN=Let's Encrypt Authority X3
* compression: NULL
* ALPN, server did not agree to a protocol
> GET /api/TrashCalendar/GetCalendarItems?portal=inwoners HTTP/1.1
> Host: www.rova.nl
> User-Agent: curl/7.47.0
> Accept: */*
> Cookie: RovaLc_inwoners={"Id":160266,"ZipCode":"7731ZT","HouseNumber":"84","HouseAddition":null,"Municipality":"Ommen","Province":null,"Firstname":null,"Lastname":null,"UserAgent":"","School":null,"Street":null,"Country":null,"Portal":null,"AreaLevel":5,"City":"Ommen","Ip":null}
< HTTP/1.1 200 OK
< Cache-Control: no-cache
< Pragma: no-cache
< Content-Type: application/json; charset=utf-8
< Expires: -1
< Server: Microsoft-IIS/8.5
< X-AspNet-Version: 4.0.30319
< X-Powered-By: ASP.NET
< Date: Mon, 31 Jul 2017 06:20:40 GMT
< Content-Length: 279
* Connection #0 to host www.rova.nl left intact
[{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2017-08-04T00:00:00","Regular":true},{"GarbageTypeCode":"GFT","GarbageType":"GFT","Date":"2017-08-18T00:00:00","Regular":true},{"GarbageTypeCode":"PLASTICPLUS","GarbageType":"PMD","Date":"2017-08-25T00:00:00","Regular":true}]
trashcan.afvalwijzerarnhem = { key:'afvalwijzerarnhem', maxitems: 5, trashapp: 'afvalwijzerarnhem', width:5,zipcode:'6832HP', housenumber:'1' }
This is the solution that works:benbammens wrote:Does not work I'm afraid. I can generate an ical url from my google calendar but since it is not a shared calendar dashticz can not see it. And I can not share it so it seems since it is an external calendar...robgeerts wrote:Try something like:
(Add your own ical url)
Var trashcan = {} trashcan.ical = { width:6, maxitems: 10, trashapp:'ical', icalurl: 'https://calendar.google.com/calendar/basic.ics' }
var trashcan = {}
trashcan.ical = { width:6, maxitems: 10, trashapp:'ical', icalurl: 'http://www.limburg.net/ics/afvalkalender/71011/9744/119/0' }
pkrabben wrote:Hi All
The recycle manager is working only I can't get the block wider then 4.
I tried
but for some reason it stays width 4 do you have any clue?Code: Select all
blocks['trashcan.recyclemanager'] = {} blocks['trashcan.recyclemanager']['width'] = 12;
trashcan.afvalwijzerarnhem = { key:'afvalwijzerarnhem', maxitems: 5, trashapp: 'afvalwijzerarnhem', width:5,zipcode:'6832HP', housenumber:'1' }wmmudde wrote:pkrabben wrote:Hi All
I tried
pkrabben, hoe heb jij deze werkend gekregen in Almere?
Hij zegt bij mij continu "undefined"
welke gebruik jij?
columns[1] = {}
columns[1]['width'] = 2;
columns[1]['blocks'] = ['garbage']
robgeerts wrote:WARNING:
In latest Beta, setting the block is done via the Settings-popup!
In this version, var trashcan = {} is not used anymore.
Do you have an example zipcode for me?kurniawan77 wrote:is it possible to inculde http://www.omrin.nl/bij-mij-thuis/servi ... alkalender too?
I forgot to mention, in the blocks, you dont add things like: trashcan.cure but just 'garbage' with the single quotes.EdKo66 wrote:robgeerts wrote:WARNING:
Now just a black screen.
edit: placed the var trashcan = {} thingy back and Dashticz works again, without the trash info. 'Undefined'.
Sure...robgeerts wrote:Do you have an example zipcode for me?kurniawan77 wrote:is it possible to inculde http://www.omrin.nl/bij-mij-thuis/servi ... alkalender too?
robgeerts wrote:I forgot to mention, in the blocks, you dont add things like: trashcan.cure but just 'garbage' with the single quotes.edko66 wrote:
