about a year ago I purchased a pre-soldered RFlink kit from Nodo Shop.
It's connected to a RPi2 which is running Domoticz 3.7518. It worked flawlessly for a year until yesterday, I never had any problems. Without changing anything, all of a sudden it cannot transmit (I am only using 433mhz) anymore:
2017-06-11 13:05:57.640 User: Admin initiated a switch command (311/Lights/Off)
2017-06-11 13:05:57.641 RFLink Sending: 10;AB400D;000060;1;OFF
2017-06-11 13:06:02.000 Error: RFLink: TX time out...Code: Select all
2017-06-11 13:41:29.286 RFLink: Controller Initialized!...
2017-06-11 13:41:29.362 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-06-11 13:41:38.818 RFLink: Controller Initialized!...
2017-06-11 13:41:38.893 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-06-11 13:41:40.394 RFLink: Controller Initialized!...
2017-06-11 13:41:51.602 RFLink: Controller Initialized!...
2017-06-11 13:41:51.678 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-06-11 13:41:52.888 RFLink: Controller Initialized!...
2017-06-11 13:41:52.964 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-06-11 13:41:58.599 RFLink: Controller Initialized!...
2017-06-11 13:41:58.674 RFLink Detected, Version: 1.1 Revision: 46 Build: 0Code: Select all
Jun 11 13:01:42 Pi-1 kernel: [50033.222797] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
Jun 11 13:01:42 Pi-1 kernel: [50033.336897] usb 1-1.3: New USB device found, idVendor=2341, idProduct=0042
Jun 11 13:01:42 Pi-1 kernel: [50033.336926] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=220
Jun 11 13:01:42 Pi-1 kernel: [50033.336944] usb 1-1.3: Manufacturer: Arduino (www.arduino.cc)
Jun 11 13:01:42 Pi-1 kernel: [50033.336961] usb 1-1.3: SerialNumber: 9543231323835161C1A0
Jun 11 13:01:42 Pi-1 kernel: [50033.338582] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM deviceIt still randomly receives 443mhz signals, i.e. my temperature sensor, but only once in a while.
I haven't touched anything for a long time, including wires and position. It just sits there and was doing its job 100%.
I am at a total loss here, is my RFlink dead?
