Question: Manual add switch (Visonic) Which TYPE?
Olgmo
Domoticz version: 4.10717
Post by Olgmo »
I have a remote control for my garage door who I used RFXmanager to find this:
Packettype    = Security1
subtype       = Visonic CodeSecure
Sequence nbr  = 154
id1-3         = D20518 decimal:13763864
status        = Light On
Now I what to add this as a switch.
But when I go to "Add manual light/switch device" I dont know which TYPE to use as Visonic is not an option.
Should it be possible and if yes, what to use? :roll:
The closest I can find is to use "meiantech Security" , but this does not seems to work (at least the door does not open).
felix63
Domoticz version: 2020.1
Re: Question: Manual add switch (Visonic) Which TYPE?
Post by felix63 »
Did you make any progress? Do you have a HBOpener garage door? As far as I understand it is 'Receive' only. No 'Transmit'. After activating Visonic in the RFX config I have added a switch for my remote by using the 'Learn' option. It shows as Visonic CodeSecure and is read only.
b_weijenberg
Post by b_weijenberg »
CodeSecure can only be used for receive. The unencrypted part is decoded for receive. The encrypted part needed for transmit is not used because of the unknown key.
RFX-433, RFX-433EMC, RFX-868
