Run every time if switch on
maglo18
Post by maglo18 »
I trying to write scrip with will be switch on and off my CWU pomp. i need condition: if switch on switch on another switch for 1 min every 10 min. My script working only when switch on but when time is triger i have info "'device' (a nil value)"
	-- 'active' controls if this entire script is considered or not
	active = true, -- set to false to disable this script
	-- trigger
	-- can be a combination:
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			'Testsw', -- device name
		timer = {
			-- timer triggers.. if one matches with the current time then the script is executed
			'every 10 minutes'
	-- actual event code
	-- in case of a timer event or security event, device == nil
	execute = function(domoticz,device)
	    domoticz.log('Alarm zmienił stan')
--	   local testsw = domoticz.devices('Testsw')
		if (device.state == 'On') then
		    local pompaCWU = domoticz.devices('Pompa CWU')
		    pompaCWU.switchOn()
dannybloe
Re: Run every time if switch on
Post by dannybloe »
Yes, the thing is, when a device triggers your script then dzVents knows which device it is and passes that to your execute script as the second parameter. If a timer triggers your script, then there is no device triggered so dzVents doesn't know what device you need. That's why the second parameter is nil when your timer is triggered. See the documentation.
So, it's an easy fix. Just get the device from the devices collection and don't use the second parameter:
local switch = domoticz.devices('Testsw')
if (switch.state == 'On') then
mivo
Post by mivo »
if I understanding correctly:
- you want check status of switch 'Testsw' every 10 minutes
- if 'Testsw' is On, switch On another switch 'Pompa CWU' for 1 minute
Try this:
   -- trigger
         -- Dont check for device, time is main trigger for your action
         timer = {
         'every 10 minutes'
      -- master switch device
      -- test status of master switch
      if (testsw.state == 'On') then
          -- slave switch device
          -- switch on slave device for 1 minute
          pompaCWU.switchOn().forMin(1)
          -- optionally turn master switch off, if needed
          testsw.switchOff()
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
maglo18
Post by maglo18 »
mivo wrote:Hi,
Yes correctly. I will try your code. Thanks.
Users browsing this forum: Google [Bot], Wiers and 1 guest
