I've been using a Foscam IP camera for a long time now with no problems. The jpeg url format is:
http://ipaddress:port/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
My Foscam just died and I purchased a new Amcrest IP2M-841. The jpeg url format is:
http://username:password@ipaddress:port/cgi-bin/snapshot.cgi?loginuse=username&loginpas=password
Is there any way to add the username:password@ into the ip address string in Domoticz. I would like to get this camera integrated.
Thanks,
Allen
Amcrest Camera
Re: Amcrest Camera
Did you ever get this to work?
I found this to help get the proper link and I can pull it up in a browser but Domoticz does not see it.
https://www.ispyconnect.com/man.aspx?n=Amcrest#
Re: Amcrest Camera
I have the same camera and for long time I was not able to use it into Domoticz even trying all the different setting suggested in the website Ispyconnect.
Reading around in the forum, if I understand correctly Domoticz is actually only managing the MJPEG Encoding and not the newest H264 Encoding.
Reading in the Amcrest firmware change log I found that latest available firmwares removed the MJPEG flux, so in order to get it working under Domoticz I put the last MJPEG firmware available that in my case is the following:
Software Version 2.420.AC00.11.R, build : 2016-01-06
In Domoticz, under Camera Setting, I set the following:
Enabled: V
IP Address: ip address of the camera
Port: 80
Username: admin
Password: password for admin user
Image URL: cgi-bin/snapshot.cgi?1
And with this setting I can confirm I'm able to get the camera image inside Domoticz.
I hope my suggestion can help you.
Greeting from Italy
Enabled: V
Port: 80
Username: admin
Greeting from Italy
