Rfxcom stops working
ubee
Domoticz version: 2021.1
Post by ubee »
I have a Domoticz configuration (v3.5877) on Rasp 2 with a RFXCom433 attached(firmware version Ext/1006). It has worked fine for a while with a few temp sensors (Viking) and Nexa switches. Occasionally I miss temperature readings from one sensor due to bad coverage, but I can live with that.
However the last few days RFXCom I have run into problems. Rfxcom stops. Or at least no temp data is received and I can't control any Nexa switch either. The log does not give any info. No lines labeled Rfxcom. Sometimes I can get things working again by re-enabling the Rfxcom HW device on the HW tab. Doing so I can see in the log how the Rfxcom module is initiated and temp readings start to come in. However, yesterday RFXcom stopped again, and this time re-enabling the HW module didn't help either. Nothing showed up in the log, but after reboot everything is fine again.
b_weijenberg
Re: Rfxcom stops working
Post by b_weijenberg »
It seems the FTDI USB interface is locked. In most cases this is due to a spike on the power or a bad RPI power supply.
Possible solutions:
Do not run the USB cable along power lines,
Use a good quality power supply,
Connect the RFXtrx to a powered USB hub (with a good quality power supply).
RFX-433, RFX-433EMC, RFX-868
