Parse variable from JSON? Topic is solved
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Hello there,
I have this JSON reply from a HTTP call:
{"Label":["12/07/2017","13/07/2017","14/07/2017","15/07/2017","16/07/2017","17/07/2017","18/07/2017"],"Data":["860","877","877","860","860","860","860"]}
I'm only interested on the last data value, the last "860" number that changes over time. It is an ultrasonic oil tank meter so I want to add the remaining litres to Domoticz but I have no idea how to do this. I have experimented a bit with LUA in the past but parsing data from a HTTP call is a complete different thing for me.
The call I do (on browser) is:
http://website.com/Report/GetChartData?SerialNo=SerialID&DeviceNo=0&NumericPeriod=0
Any pointer to help me get started would be fantastic! :D
11101101 - www.machinon.com
Egregius
Domoticz version: v2024.7
Re: Parse variable from JSON?
Post by Egregius »
Easy in PHP, no clue in Lua :?
<?php
$data=json_decode(file_get_contents('http://website.com/Report/GetChartData?SerialNo=SerialID&DeviceNo=0&NumericPeriod=0
'),true);
echo $data['Data'][6];
mivo
Post by mivo »
there should be JSON.lua library in scripts/lua Domoticz subfolder. Documented here or in script itself:
https://www.domoticz.com/wiki/Lua_-_json.lua
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
EdddieN
Post by EdddieN »
aha! I missed that completely within the wiki. Thanks for the link :)
EdddieN
Post by EdddieN »
I must admit, it looks so simple in PHP... I need to look into it.
Anyway, this is how I managed at the end. Since I'm a LUA (and PHP) ignorant, feel free to improve on it. It seems to work for me:
local t1 = os.date("%H") -- get hour time digit
if t1%23 == 0 then -- only poll at 11pm every day
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
       --  API call
       local config=assert(io.popen('curl "http://website.com/Report/Getdata..."'))
       local Stringjson = config:read('*all')
       config:close()
       local jsonData = json:decode(Stringjson)
       oil = jsonData.Data[6]
print (Stringjson)  -- debug json
print (oil) -- parsed json value
commandArray['UpdateDevice'] = 465 .. "|0|" .. oil -- update sensor value
EdddieN
Post by EdddieN »
Ooopps my mistake. The script will run for 1 hours at 23:00, so it needs a something like:
local t2 = os.date("%M") -- get minute time digit
if t1%23 == 0 and t2%01 == 00 then
Ittiz
Domoticz version: 13939
Post by Ittiz »
I believe there is now a JSONdecode fuction for LUA in the latest beta version of Domoticz, no library needed.
EdddieN
Post by EdddieN »
Still on stable version...
Quick thing, I added a new device for calculating the level of the tank, something like this:
Oilpercentage = (oil * 100) / 1400
print (Oilpercentage)
commandArray['UpdateDevice'] = 472 .. "|0|" .. Oilpercentage -- update sensor value
and now, only the last one "Oilpercentage" updates, the other one does not. Any idea why?
mivo
Post by mivo »
Yes, because last assignment of commandArray wins. Multiple commands should be passed in LUA table like this:
commandArray[1]={['UpdateDevice']='465|0|' .. oil}
commandArray[2]={['UpdateDevice']='472|0|' .. oilPercentage}
My toys:
EdddieN
Post by EdddieN »
mivo wrote:Yes, because last assignment of commandArray wins. Multiple commands should be passed in LUA table like this:
thanks, that did the trick!
EdddieN
Post by EdddieN »
This has been working well for a long while, however it always reports the third number from the end. This is the reply:
{"Label":["05/04/2018","06/04/2018","07/04/2018","09/04/2018","10/04/2018","11/04/2018"],"Data":["407","407","376","360","360","344"]}
and my code:
if t1 == "22" and t2 == "30" then -- only poll at 11pm every day
json = (loadfile "/home/pi/domosense/scripts/lua/JSON.lua")()  -- For Linux
       --  API call
       local config=assert(io.popen('curl "http://website.com/Report/GetData?SerialNo=xxxxx"'))
       config:close()
-- print (Stringjson)  -- debug json
-- commandArray['UpdateDevice'] = 465 .. "|0|" .. oil -- update sensor value
Oilpercentage = (oil * 100) / 1250
-- commandArray['UpdateDevice'] = 472 .. "|0|" .. Oilpercentage  -- update sensor value
commandArray[2]={['UpdateDevice']='472|0|' .. Oilpercentage}
Instead of returning 344, it returns 360. Any ideas where am I going wrong?
EdddieN
Post by EdddieN »
Is this still working on the latest beta V3.9390 : https://www.domoticz.com/wiki/Lua_-_json.lua
After an update it seems to have stopped for me.
