Razberry Zwave Nodes disappears after reboot
bks84
Domoticz version: 3.8153
Post by bks84 »
Hello everyone,
Can anyone tell me what I should look for to make sure that the Zwave nodes does not disappear after a reboot? As soon as I stop the Domoticz service and remove the Zwcfg XML file and restart the service, the Zwave nodes are visible and are working fine. However as soon as I reboot the Raspberry Pi the Zwave nodes are gone again. I cannot find any solution for this, I hope someone can point me in the right direction.
Thanks in advance!
dressie
Domoticz version: V2020.2
Re: Razberry Zwave Nodes disappears after reboot
Post by dressie »
I got the same thing. I just upgrade my hardware to a small PC running Linux. It's so fast that the Zwave Stick is not ready yet before Domoticz is loaded. This means I have to stop and start Domoticz before Zwave NODES return to Domoticz.
Is there a way to delay the startup by some time?
mivo
Post by mivo »
you can add delay to startup script of Domoticz, for example:
/bin/sleep 10
Numeric argument is time in seconds.
If using systemd unit, there are many different options...
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
dressie
Post by dressie »
mivo wrote:Hi,
/bin/sleep 10
Thanks! Willing to try this, could you tell me where to add this line (almost no noob anymore) Image?
Verstuurd vanaf mijn SM-G920F met Tapatalk
mivo
Post by mivo »
Copy for backup, and then open startup script /etc/init.d/domoticz.sh with preferred editor (vi, nano etc.)
Search for these lines:
case "$1" in
  start)
        [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
        do_start
Add sleep line:
case "$1" in
  start)
        /bin/sleep 10
        do_start
My toys:
bks84
Post by bks84 »
mivo wrote:Copy for backup, and then open startup script /etc/init.d/domoticz.sh with preferred editor (vi, nano etc.)
case "$1" in
  start)
        do_start
Add sleep line:
case "$1" in
  start)
        /bin/sleep 10
        do_start
I just tried this, but unfortunately it did not worked.
bks84
Post by bks84 »
I have reinstalled Domoticz from scratch and now it seems that the problem has been resolved :D
