All, I must be thick but I cannot get this power usage actual to work. I have a device (Fridge) of type Usage subtype Electric where I am trying to print its value:
active = true,
devices = {
'Fridge'
execute = function(domoticz, dev)
pow = dev.WActual
print('Dev power says ' .. pow)
Domoticz complains about concatenating a string and a nil value (pow). What am I doing wrong here?
dzVents WActual Nil issue
- heggink
- Domoticz version: 12451
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
mivo
Re: dzVents WActual Nil issue
try to convert pow value (numeric) to string before print, for example:
print('Dev power says ' .. tostring(pow))My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
dannybloe
Yes, you have to convert it to a string otherwise lua will complain. Interesting thing here though is why it is nil. You can turn debug logging on and inspect the log. You can also inspect the file domoticzData.lua that will be created in debug mode in /path/to/domoitcz/scripts/dzVents. Or you can do dev.dump() to dump all device attributes to the log.
- heggink
Found it: it should be WhActual with an h after the W. I followed the wiki so is there a typo? WActual: Number. Current Watt usage.
DASHTICZ 🙃
DASHTICZ 🙃
dannybloe
Yup. That's likely a typo.
- heggink
Yay for the dump() function. That's how I noticed the correct name.
DASHTICZ 🙃
DASHTICZ 🙃
dannybloe
I fixed the typo in the docs.
