Dummy switch won't turn on
tapas
Post by tapas »
Hello, I've been pulling my hair off over this seemingly very simple script that should turn a dummy switch (idx 22) on:
commandArray['UpdateDevice'] = '22|1|On'
I'm trying to run it from linux shell lua script.lua with no luck, what am I missing?
pvm
Domoticz version: 4.10538
Post by pvm »
It seems to be missing
'return commandArray'
For examples check the wiki
tapas
Re: Dummy switch won't turn on
Post by tapas »
Thanks for the reply, I added that but still no luck :(
mivo
Post by mivo »
tapas wrote:I'm trying to run it from linux shell lua script.lua with no luck, what am I missing?
starting LUA script from Linux shell will not work, there is no Domoticz API available. You should create script in designated folder and correct name - in subfolder of domoticz installation: scripts/lua. Then scrips are started by Domoticz event system.
Look at this, there are good examples:
https://www.domoticz.com/wiki/Events#By ... ion_folder.
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
tapas
Post by tapas »
Yes, it works now, thank you! One of my problem was that script names were wrong. Should have read that wiki better.
